oil breather
Old May 1, 2004 | 02:40 PM
drPepperStyles's Avatar
Default oil breather
did a search but couldnt find exact answer.
im puttin my 00si back to stock n need to know what the two holes on top of the oil breather chamber go to? TIA
Old May 4, 2004 | 01:58 AM
JDMorgan's Avatar
the one on the timing belt side goes to the fitting directly above it on the block, sticks out of the block like 2". then the one on the tranny side goes up to the intake mani between cyl 1+2 to the pcv valve. the other side of the pcv valve goes to the intake manifold.
Old May 4, 2004 | 07:33 AM
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">the one on the timing belt side goes to the fitting directly above it on the block, sticks out of the block like 2". then the one on the tranny side goes up to the intake mani between cyl 1+2 to the pcv valve. the other side of the pcv valve goes to the intake manifold. </TD></TR></TABLE>
THANKS
jamison1486
Aug 4, 2007 09:03 AM
DaX
May 23, 2004 07:11 AM
Jeff C
Nov 4, 2002 12:47 PM
xtrafastcivic
Mar 25, 2002 01:22 PM
rainforest
Jan 5, 2002 07:43 AM
