odyssey pc680 battery not charging
Old Jun 14, 2017 | 07:58 AM
br8crumb's Avatar
Default odyssey pc680 battery not charging
sup guys. running a pc680 in the trunk on my weekend warrior. only electronics on the car are headlights/blinkers and then a radio plus a fan switch wired directly to the battery. if I open up hondata and turn the key, the battery shows 12.3v. when cranking drops down to 11.2v and sometimes will be enough to crank the motor over, and then go up to 14V fluctuation between 13.95-14.25 while the motor runs. I could drive for 5minutes or a hour and when I shut the car down, the battery voltage will show 12.1-12.3V. sounds like the battery is to blame yes? have it on a charger at the moment to see how much voltage it will actually hold and if it drops after I install/let it sit
Old Jun 14, 2017 | 08:49 AM
br8crumb's Avatar
Default Re: odyssey pc680 battery not charging
Update battery tested 13.5v when on charger after a hour but when putting back in car reads 12.5 and dropped to 12.39 steady
Old Jun 17, 2017 | 12:52 AM
holmesnmanny's Avatar
that's normal, it will bleed off after you shut the car off
unless it's not starting it's fine
Old Jun 19, 2017 | 08:06 PM
br8crumb's Avatar
anything under 12.3v wont start the car. using 0 gauge wire but battery in trunk so might be too far away
crxaddikt
Apr 5, 2009 01:45 PM
hatch_
Aug 8, 2008 12:48 PM
Turbo_Mike
Apr 30, 2006 06:25 AM
kupras
Dec 14, 2005 02:59 PM
MooreBoost
Audio / Security / Video
Jan 27, 2005 03:53 AM
