Corn Fuel?
Old May 5, 2008 | 08:42 PM
ToryluvshisDA's Avatar
Default Corn Fuel?
ive got a 91 DA w/ b18 and im wondering what i need to do to the engine to make it run on flex fuel or ethonol..any opions
Old May 5, 2008 | 09:17 PM
Rickdrizzle's Avatar
Don't quote me on this, but you won't benefit much unless you're running on bigger injectors, better fuel pump, and of course a tune.
Old May 5, 2008 | 09:35 PM
davidluko's Avatar
Not that he won't benefit, but that's what he *needs* to run on ethanol from what little I've read about it. I think it's cheaper and gets better MPG though or something like that, but of course it's harder to find a place to fill up with it. That's as far as I know. I'm interested in it too though... I'm pretty sure it also has higher octane so you can tune your timing more aggressively.
Old May 6, 2008 | 03:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Corn Fuel? (ToryluvshisDA)
You would want to run E85 for the increased octane rating to make more power. The FI guys have done this. E85 will produce lower fuel economy (MPG) than gasoline. The main problem with running E85 in an Integra is that you would always have to run the fuel. flex fuel vehicles have sensors that can determine the fuel mixture in the tank and the ECU compensates. Your car does not have this flex capability.
Old May 6, 2008 | 10:17 AM
Default Re: Corn Fuel? (Dogginator)
so in other words i would need to run E85 all the time and never mix gas into it? its alot cheaper then regular gas isnt it? and it get about the same mpg
Old May 6, 2008 | 11:30 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToryluvshisDA &raquo;</TD></TR><TR><TD CLASS="quote">so in other words i would need to run E85 all the time and never mix gas into it? </TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToryluvshisDA &raquo;</TD></TR><TR><TD CLASS="quote">its alot cheaper then regular gas isnt it?</TD></TR></TABLE>
I thought they cost about the same per gallon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToryluvshisDA &raquo;</TD></TR><TR><TD CLASS="quote">and it get about the same mpg</TD></TR></TABLE>
E85 fuel economy is about 30% less than gasoline fuel economy. (Pulling 30% from memory.)
Old May 6, 2008 | 01:52 PM
then whats the point?
Old May 6, 2008 | 02:06 PM
94rs94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToryluvshisDA &raquo;</TD></TR><TR><TD CLASS="quote">then whats the point?</TD></TR></TABLE>Another alternative; trying to get away from the east!
Old May 6, 2008 | 04:11 PM
davidluko's Avatar
Oops my bad, I knew it either had better or worse fuel economy but like I said I haven't looked into it much and just read about it a littel bit, a long time ago. The point is for higher octane for performance, and as an alternative to gas for car companies to start using.
Old May 6, 2008 | 04:46 PM
e85 = consider it to be a high octane. 100ish octane.
only downside would be crappier MPG compared to 87 octane.
yannibeee
13
Mar 15, 2016 02:43 PM
hello1320
Feb 19, 2012 02:24 PM
s032105k
11
Apr 14, 2011 08:01 PM
projekt-sol
Dec 18, 2007 06:56 PM
rharris84
Jan 19, 2007 07:33 AM
