obd2a to obd1!!!!!!!!!!!HELP!!!!!!!!!!!
Old May 28, 2006 | 06:30 AM
VRD^don's Avatar
Default obd2a to obd1!!!!!!!!!!!HELP!!!!!!!!!!!
okay guys...just got done with the swap..obd1 ls into a 96 hatch..got all the wiring done..dropped the motor in..plugged everything up...went to start it..nothing..motor cranks over but nothing..motor cranks over very fast for some reason..i know its getting fuel cause i took all the plugs out and they were wet and smelled of fuel..im pretty sure its the wiring of the dizzy..but i searched the forum and found this..so i followed what it said..dont know what to do..im stumped guys..help me out..is this the correct diagram or not..car is being converted to obd1 BTW
Old May 28, 2006 | 06:31 AM
VRD^don's Avatar
Default Re: obd2a to obd1!!!!!!!!!!!HELP!!!!!!!!!!! (k_motor)
motor now starts..but everytime i give a little throttle..motor wants to cut out..
Old May 28, 2006 | 06:34 AM
VRD^don's Avatar
motor is out of a 94 integra LS
Old May 28, 2006 | 03:01 PM
VRD^don's Avatar
Old May 29, 2006 | 01:39 PM
VRD^don's Avatar
can anyone confirm if thats the right daigram to use?
Old May 29, 2006 | 02:43 PM
johnnylaw's Avatar
everything is right except for the green wire. there isn't one on the obd1 distributor. orange/blue goes to green on the TDC
Old May 29, 2006 | 06:39 PM
VRD^don's Avatar
Default Re: obd2a to obd1!!!!!!!!!!!HELP!!!!!!!!!!! (racingtechnologyco.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingtechnologyco.com &raquo;</TD></TR><TR><TD CLASS="quote">everything is right except for the green wire. there isn't one on the obd1 distributor. orange/blue goes to green on the TDC</TD></TR></TABLE>
cools.thanks..the car now runs...but misfires from 1k-4k rpm while normal driving..4500-7500 rpm it runs fine..
Old May 30, 2006 | 07:26 AM
HondaPartsHero's Avatar
Technical Hero
Old May 31, 2006 | 11:28 AM
VRD^don's Avatar
Default Re: obd2a to obd1!!!!!!!!!!!HELP!!!!!!!!!!! (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
bump..thats the same diagram as the one above i posted..
Old May 31, 2006 | 11:37 AM
VRD^don's Avatar
well..thinking that the ignitor was fried...i did switch ignitors from a dseries into the LS dizzy...do you think this will cause it to miss fire??
Old May 31, 2006 | 04:08 PM
Technical Hero
Sorry edited from my above to reflect thick blue and thin blue as opposed to dark and light blue. The Poison diagram above has an incorrect TDC + that shows green to green but the OBD1 harness has no green but other than that is correct
Old May 31, 2006 | 04:43 PM
VRD^don's Avatar
got you on that..blue green(obd1) goes to green (obd2) right??
vietnamezerice
Jan 15, 2020 04:00 PM
VRD^don
26
Jun 1, 2006 11:00 PM
BuiltB18C1
Oct 27, 2003 07:11 PM
Skunk2Civic94
Jun 4, 2002 05:46 PM
