obd2 and obd2v2???
Old Jul 11, 2003 | 05:33 AM
1man's Avatar
Default obd2 and obd2v2???
hey guys, sorry that i have to post this simple question, because i couldnt find anything with the search function. So what is/are the diff(s) between the two? I have a 97 teg, which is obd2, and im getting a 2000 gsr head, with 98 gsr block. from what i kno, 96-98 = obd2, and 99-01 = obd2v2, and since im getting an obd2v2 head with an obd2 block on an obd2 car, would this swap be possible using obd2v2 ecu? is the head & block compatible? i kno it's confusing i hope u guys understand what im trying to say here..
Old Jul 11, 2003 | 03:14 PM
urname7698's Avatar
Default Re: obd2 and obd2v2??? (Gin 'n Juice)
I can shed some light on this.. As far as i know OBD2a vs OBD2b is in the harness/ECU only. OBD2a uses 3 plugs at the ECU, OBD2b uses 2 plugs at the ECU. The wiring harness for OBD2a is a continue harness from engine to ECU, while the OBD2b has a seperate harness for cabin and engine bay.
So, to answer your question, there are no differences in the connectors in the engine bay, just at the ECU/Harness.
Are you going to be using the OBD2b ECU? You could use the harness then, but bear in mind some of the 00-01 ECUs have immobilizers
Lastly, OBD2v1=OBD2a, OBD2v2=OBD2b, etc..
Also: check out these harnesses- they will show the connectors @ the ECU
https://honda-tech.com/zerothread?id=539315
Old Jul 11, 2003 | 03:50 PM
1man's Avatar
Default Re: obd2 and obd2v2??? (urname7698)
thanks for the useful infos. One more stupid question, what did u mean by "some of the 00-01 ECUs have immobilizers" ?
Old Jul 11, 2003 | 03:58 PM
orange.honda's Avatar
a special thaNX TO THE PEOPLE AT HONDATA FOR THE PIC.
from top to bottom:
obdIIb
obdIIa
obdI
obd0
Old Jul 11, 2003 | 05:04 PM
urname7698's Avatar
- some of the 00-01 ECUs have immobilizers
I know that USDM b18c5 (ITR) ECUs have immobilizers that will prevent the car from being started unless the matching key (with a chip) is inserted. I believe that the Integra GSRs 2000-2001 have them too, but I am not positive what others.
jdmchickx
10
Oct 26, 2011 06:03 PM
ej8
Aug 1, 2011 12:55 AM
halocore
Dec 21, 2008 05:58 PM
LSVTEC_ALLMOTOR
Dec 21, 2004 04:49 PM
lsvtec101
May 28, 2004 02:11 PM
