How to clean this up?!
Old Jul 10, 2003 | 09:07 AM
GhettoBrawls's Avatar
Default How to clean this up?!
I want to clean my block up before sending it to the machine shop. How did you get urs looking new??
I used some purple power cleaner and got me to this point.
Old Jul 10, 2003 | 09:14 AM
STOLEN - ITR 98-0652's Avatar
Default Re: How to clean this up?! (GhettoBrawls)
Simple Green. Nylon Brush. Pressure Washer.
Although the shop should tank it as a matter of course.
Old Jul 10, 2003 | 10:37 AM
servion's Avatar
Default Re: How to clean this up?! (ITR 98-0652)
have the machine shop hot tank it. My machinist wouldn't even hone it before he hot-tanked it... something about not getting all the crap from my block in his machine. It's a pretyt standard practice to have a block hot-tanked.
Old Jul 10, 2003 | 10:53 AM
well, i'm bored and i want to clean it myself!! before they clean it.
Old Jul 10, 2003 | 11:00 AM
romeo619romeo's Avatar
Default Re: (GhettoBrawls)
engine bright and a rag .. you prolly need 2 ans of engine bright
Old Jul 11, 2003 | 07:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (romeo619romeo)
Hot tanking aluminum blocks is not good...have them cold tank it.
Old Jul 11, 2003 | 08:23 AM
GZERO's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Hot tanking aluminum blocks is not good...have them cold tank it.</TD></TR></TABLE>
True, or pressure wash it (the special machine, not the one that you can buy)
Old Jul 11, 2003 | 08:24 AM
976's Avatar
976
New User
Default Re: (GZERO)
Let the cleaner soak for an hour at least, will be much easier for you then.
Old Jul 11, 2003 | 10:43 AM
Kataku2K3's Avatar
Default Re: (976)
Whatever method to clean it, hot tanking works well... I normally spray most of my blocks but glass beading or even sand blasting work awesome... The problem with paint is that it's very hard to clean as you can NOT use brake cleaner, etc... Glassbeading gets my vote tho Good Luck
Old Jul 11, 2003 | 11:17 AM
Blazin Si's Avatar
Loved
Community Favorite
i use Never Dull... it works pretty good. when cleaning my engine i usually use Simple Green and a few brushes, but that did nothing for the carbon build-up around the header.
on the left you can see the part i cleaned, and on the right is what it looked like before i used the Never Dull. (ignore the duct tape, that's temporary until i can find a Del Sol VTEC a/c bracket)
i think if you try this stuff, you'll be able to get it pretty clean. it will take some time, but if you have the patience i think you'll be happy with the way it will turn out.
Old Jul 11, 2003 | 11:47 AM
vteckid33's Avatar
Default Re: How to clean this up?! (Blazin Si)
How much does the never dull cost
Old Jul 11, 2003 | 01:09 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: How to clean this up?! (vteckid33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckid33 &raquo;</TD></TR><TR><TD CLASS="quote">How much does the never dull cost
like 3 or 4 bucks, if i remember correctly.
Old Jul 11, 2003 | 02:48 PM
iakona's Avatar
don't use simple green on aluminum!!!! it'll ruin it.
Old Jul 11, 2003 | 04:05 PM
RCautoworks's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">don't use simple green on aluminum!!!! it'll ruin it. </TD></TR></TABLE>
Not if you get the one ment for automotives.
Old Jul 11, 2003 | 04:10 PM
VTECorona's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Not if you get the one ment for automotives.</TD></TR></TABLE>
And if you use it correctly. (cold motor, rinse properly, etc)
Old Jul 11, 2003 | 06:29 PM
wm5holla's Avatar
Default Re: (VTECorona)
i am scared about what if it getts into my pistions,, wont that be bad? is the block paint? i was thinking blue
crx_saru
Nov 20, 2009 03:58 PM
SOHC_me
Jan 13, 2007 07:40 AM
B16'D DA9
12
Jun 13, 2005 03:53 PM
Kwuaymaikrup
Jan 22, 2003 06:15 AM
brasilracing
10
Jul 22, 2002 01:02 PM
