obd2 to obd1: rewiring distributor, HELP?
Old Jan 12, 2006 | 02:57 AM
f2m0u5's Avatar
Default obd2 to obd1: rewiring distributor, HELP?
i need help rewiring my dizzy.. i found other threads on here about how to wire it up, but when i did it, i was one wire short.. im not to sure if my dizzy is a obd2a or b.. it has 8 wires, can anyone out there help me out?? im guessing its obd2a, cause i heard there usually square shape.. were obd2b are more rectangler.
Modified by 0LlY at 2:50 PM 1/12/2006
Old Jan 12, 2006 | 12:09 PM
f2m0u5's Avatar
Default Re: obd2 to obd1: rewiring distributor, HELP? (0LlY)
bump for some help
Old Apr 5, 2006 | 02:36 PM
Ch3mik's Avatar
obd2a are more square
Old Apr 5, 2006 | 03:55 PM
EE_Chris's Avatar
OBD2b is what used 8 wires. It lacks the Blu tach output wire.
Old Apr 6, 2006 | 07:33 AM
Ch3mik's Avatar
Default Re: obd2 to obd1: rewiring distributor, HELP? (EE_Chris)
you have an obd2b dist . the extra blu wire on the dist goes t the blue wire by itself on the drvr side near the firewall. it has a plastic plug cover by a rubber sleeve on the end of it.
Old Apr 6, 2006 | 07:39 AM
EE_Chris's Avatar
Default Re: obd2 to obd1: rewiring distributor, HELP? (Ch3mik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">you have an obd2b dist . the extra blu wire on the dist goes t the blue wire by itself on the drvr side near the firewall. it has a plastic plug cover by a rubber sleeve on the end of it. </TD></TR></TABLE>
Why? That blue wire sitting over by the drivers side is a tach output from the ECU.
Old Apr 6, 2006 | 09:44 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
Why? That blue wire sitting over by the drivers side is a tach output from the ECU.</TD></TR></TABLE>
with an OBD2b ECU yes, that blue wire at the driver's shock tower is connected to the tach output signal of the ECU, something new from OBD2a to OBD2b.
BUT with an OBD2a or OBD1 ECU you need that blue wire from the distributor.
Old Apr 6, 2006 | 02:35 PM
Ch3mik's Avatar
Default Re: obd2 to obd1: rewiring distributor, HELP? (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">with an OBD2b ECU yes, that blue wire at the driver's shock tower is connected to the tach output signal of the ECU, something new from OBD2a to OBD2b.
BUT with an OBD2a or OBD1 ECU you need that blue wire from the distributor.</TD></TR></TABLE>
yep
CivicBlacksheep
Jun 5, 2025 12:28 PM
Weifast
Jul 16, 2014 07:17 PM
sawedoffcoupe
Jan 3, 2009 04:40 AM
91CivicHatchback
May 22, 2005 03:45 PM
