OBD2 Engine > OBD1 Engine in a 1996 DX Hatch
Old Aug 14, 2002 | 09:20 PM
2000_Civic_Si's Avatar
Default OBD2 Engine > OBD1 Engine in a 1996 DX Hatch
Hey all have some questions about changin over my 96 DX hatch over to obd1. Specifically i want to put an obd1 engine and ECU into the car, what all will i need and how hard will it be. I don't have many power options, I have manual windows, manualy mirrors, manual steering rack ( no PS ), no sunroof, no cruise. Prettymuch the only option i have is A/C which will get tossed when i do the swap....i'm thinkin LS/VTEC as my engine and i'm still thinkin about tranny but that can't be a last thing it doesn't matter....i heard it can be done if i could get the body harnesses to match up but since i don't have maybe options it shouldn't matter should it. Any info is welcomed.
Old Aug 15, 2002 | 12:47 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: OBD2 Engine > OBD1 Engine in a 1996 DX Hatch (2000_Civic_Si)
......Specifically i want to put an obd1 engine and ECU into the car, what all will i need and how hard will it be.
Why? For all the work necessary, the gains are minimal. Use a OBD2 engine, and then get a OBD2-1 converison harness and run a OBD1 ecu.
What does this have to do with swapping the engine????
Pretty much the only option i have is A/C which will get tossed when i do the swap....
Again, why? You don't like AC? Or do you live in a cold climate??? AC is easy to keep, and well worth it. The weight savings are minimal at best when removed. If you're going to remove the AC for weight savings, might as well take out the heater core, and fans too......
I'm thinking it if this is your first swap, don't go LSVTEC. If you don't have much mechanical experience, then and LSVTEC is not a good starter motor to swap in.
If you're on a budget, go B20B/Z from a 98+ CRV, and swap it in.
If you're NOT on a budget, and just want MASSIVE power, a H22 swap would be your best bet.
Late.
Old Aug 15, 2002 | 06:30 AM
CHEETAH's Avatar
doesnt matter if you put obd1 or obd2 engine in car ... you will need a 99-00 civic Si engine harness and ecu, and mounts to make life much simpler ... I have extra harnesses and ecus ... shoot an email if interested ... you can always get an obd2(99+) to obd1 ecu adater later on.
greg
Old Aug 15, 2002 | 08:30 AM
fowler!'s Avatar
Default Re: OBD2 Engine > OBD1 Engine in a 1996 DX Hatch (CHEETAH)
You can not use a 99-00 Si harness without rewiring the entire underdash harness or without repinning every single pin.
Seeing as he has a 96-98 Civic, the only harness that you can use is one that came from those years. An ex harness will be a little bit easier.
Anyways...this is what you will need to put an OBD 1 motor into an OBD 2 car.
Distributor, injectors and OBD1 ecu.
The OBD 1 distributor won't match up with the OBD 2 harness, so all you have to do is swap it out or rewire the dist. to work. It can be done..just match up the colors.
The injectors are the same thing. The plugs don't match up, so just swap them out for their OBD2 siblings. Or, like I said above, rewire them to work with the OBD2 harness.
If you run the OBD1 motor, you're gonna want to use an OBD1 ecu. Only for the fact that an OBD2 ecu will look for sensors that the older motor doesn't have, thus, you will have a few CELs.
To run the OBD1 ecu in your car, just buy the converter harness from Kenji or from Skunk2.
Check this for more info: http://www.jspectuning.com/6gen
Old Aug 15, 2002 | 11:30 AM
CHEETAH's Avatar
Default Re: OBD2 Engine > OBD1 Engine in a 1996 DX Hatch (fowler)
thats news to me since I've done it 3 times now for customers and everything worked fine ...
Greg
Old Aug 15, 2002 | 12:16 PM
fowler!'s Avatar
That's weird seeing as the end of the harness doesn't match up with the cabin plugs, nor an OBD 2 ver.1 ecu..
Petey Puff
Oct 22, 2007 04:02 PM
soon2bdropped
Jul 23, 2007 01:37 PM
SiMateoAko
Oct 8, 2005 05:00 PM
2000_Civic_Si
Aug 15, 2002 03:24 AM
