ex-si tranny questions
Old Aug 14, 2002 | 09:31 AM
hondafrk's Avatar
Default ex-si tranny questions
what does it normally mean when it is hard to downshift the tranny into first gear at speeds above 25 mph. its a 95si tranny.
Old Aug 14, 2002 | 09:48 AM
Dokta's Avatar
Default Re: ex-si tranny questions (hondafrk)
It means that the interlock is working to prevent you from downshifting into first and destroying your engine. If you are going faster than 20 mph and you can downshift into first in that tranny, the interlock is not working.
Old Aug 14, 2002 | 10:28 AM
jdmillusion's Avatar
Default Re: ex-si tranny questions (Dokta)
and so my light bulb went on...
Old Aug 15, 2002 | 04:15 AM
Mista Bone's Avatar
D Tranny Guru
What have you been smoking???????????
More useless BAD info!!!!!!
There is no interlock to prevent shifting into first, no matter WHAT the speed. Trying to get the synchro to spin up the shaft speed to allow you to get into first is the problem. You have to apply pressure which will sometimes break the 1-2 shifter fork.
Now if you downshift properly, it slides right into 1st.
Try going 40 mph in 4th and downshifting into 1st without grinding or excessive pressure.
Very simple..............
Double clutch.
Old Aug 15, 2002 | 04:55 AM
Mr Furball's Avatar
Default Re: ex-si tranny questions (Mista Bone)
what about rev match..
Old Aug 15, 2002 | 12:27 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: ex-si tranny questions (FURBALL B-16)
"rev matching" doesn't speed up the shafts, only double clutching will.
SkaiWu
Nov 6, 2008 09:53 AM
B18cHatch06
May 29, 2008 12:55 PM
GT30RSX
Feb 21, 2007 10:45 PM
Mostec_EG
May 27, 2003 11:04 PM
