obd2 EK only starts with obd1 ecu ?
Old Jan 5, 2009 | 10:32 PM
Dyce's Avatar
Default obd2 EK only starts with obd1 ecu ?
i have an ek with a b16a2 swap. everything on the car is obd2. obd2 injectors, obd2 alt., obd2 distributor. for tuning purposes i bought a stepdown to obd1 and a p28. no problems there. but when i try to use a p2t or p2e ecu, the car will crank forever and not start. when i tryed plugging in an obd2 type r ecu, one of the plugs didnt match.
what could be the problem?
Old Jan 5, 2009 | 11:17 PM
jdm602's Avatar
Default Re: obd2 EK only starts with obd1 ecu ?
you know theres obd2a and obdb?
also, what harness is it?
Old Jan 6, 2009 | 12:46 PM
Dyce's Avatar
yea i know that. the kid i bought the harness from claims that it was a 2000 si harness (obd2b) so i dont seewhy the p2t and p2e ecu's dont work.
i guess i answered half my own question since type r ecu's are obd2a ?
Old Jan 6, 2009 | 12:53 PM
jdm602's Avatar
im guessing with that p28 that your using a obd2b to obd1 jumperharness? just run it on that.
Old Jan 6, 2009 | 03:04 PM
doc's Avatar
doc
The most OBD2a and OBD2b ECUs has a Immobilizer System installed.
Maybe the ECUs you tried are not programmed to your Key or does not match the Immobilizer System of the car. If so, you need to let the ECU programm to match your Key or remove the Immobilizer System from the ECU.
Old Jan 6, 2009 | 03:31 PM
jdm602's Avatar
really? my si doesnt have one. i thought it was only the itr's and gsr's?
Old Jan 6, 2009 | 04:19 PM
doc's Avatar
doc
I just can say the "most". Here even the EJ9 (1.4 SOHC, 75HP) Civics are equipped with a IMMO System. Maybe it's different in your location.
But it wouldn't waste too much time to open then ECU's top cover and look inside for a IMMObilizer Board (you can find more information on my site (see my signature) for what you have to look for). If you not sure about, just send me pictures of the ECU (of course with cover removed), so i can tell you if there is a IMMO system installed or not.
Old Jan 6, 2009 | 05:44 PM
Dyce's Avatar
never knew about that. idk if they have that here in the states but it doesnt hurt to look.
you mentioned why not continue to use the stepdown to obd1 and p28? because i need to be obd2 in order to pass inspection
Old Jan 6, 2009 | 06:32 PM
jdm602's Avatar
im not sure how emissions work with obd2. idk how the obd scanner will work trying to read the obd1 ecu when they plug it in, or if it even matters. anyone care to jump in? i would think as long as there is no check engine it should be fine. you can just throw the stock b16 map on the p28.
Old Jan 6, 2009 | 09:45 PM
Dyce's Avatar
depends on where you go. some places use the plug. and the obd1 computer doesnt read in and obd2 car. meaning automatic inspection fail.
Old Jan 6, 2009 | 09:50 PM
salbaje's Avatar
here in the states only 99-00 Itr has immobilizer on the p73 ecu. How many plugs on the ecu side does your harness have?? i think the 96-98 only has 3 plugs and the 99-00 engine harness has 4 plugs 3 plus a green plug
Old Jan 7, 2009 | 04:20 AM
DIABOLIC8's Avatar
I have the same problem on my ek, but i figured out that i have a ex harness. The harness i have has a 2 wire iacv plug, which is what ppl use when doing a b series, vtec swap. The stock ecu wont let the car start cuz its trying to read the original 3 wire connector on the stock harness, but when i use my obd1 it runs like new. Check to see if its throwing a p1509 code? if so then your in the same boat with me.
Old Jan 7, 2009 | 11:57 AM
Dyce's Avatar
hmm im not exactly sure how many plugs i have because i put my car away for the winter. but when i look ill reply back. i think my harness had 3 plugs though.for the record, is their a obd2b-obd2a conversion harness in existance?
Old Jan 7, 2009 | 11:59 PM
Dyce's Avatar
anybody else have any input?
Old Jan 8, 2009 | 06:16 AM
DIABOLIC8's Avatar
http://www.boomslang.us/obd2to2.htm
I found this harness, ppl i know tell me boomslang works good.
StraussBuster
Sep 18, 2013 11:32 AM
egbaby
Mar 1, 2008 06:52 AM
screen_name
Apr 22, 2006 06:56 PM
shawnc21
Jan 9, 2003 11:21 AM
Spartanic
Mar 31, 2002 05:26 PM
