OBD2 Diagnostic Port
Old Apr 2, 2006 | 10:37 AM
MrCivic98's Avatar
Default OBD2 Diagnostic Port
I recently swapped in an OBD1 motor (jdm b16) into my 98 coupe (OBD2). I am running my old d16y8 harness to an obd1 ecu via a conversion harness. Here in New York, to pass emmissions, the inspector plugs into the obd2 diagnostic port found under the steering column. I believe that they read if the computer is throwing any codes and if it is, it will fail the inspection. Since im running an OBD1 computer but the diagnostic port is still present in the car, what will happen? Any help would be greatly appreciated...these expired inspection tickets are adding up!
Old Apr 2, 2006 | 10:42 AM
ChicagoMike's Avatar
Default Re: OBD2 Diagnostic Port (MrCivic98)
The diagnostic port will not give the inspector any kind of reading on the car. I'm pretty sure you will fail.
Old Apr 2, 2006 | 10:44 AM
MrCivic98's Avatar
Default Re: OBD2 Diagnostic Port (RippinVTEC)
thats what i thought...thanks man.
anyone else?
uses0ap
Feb 17, 2009 01:16 PM
mitchell_2kSiR
May 23, 2008 01:49 PM
NOman0608
Jul 26, 2007 10:28 AM
akoreanyoungsta
Jul 8, 2006 06:22 PM
