distributor
Old Jan 7, 2006 | 12:37 PM
SupraRXZ's Avatar
Default distributor
can I use a 90-93 obd0 distributor on a 99 LS motor? im doing a swap into a EF and coverting everything to obd1, but i was going to use the distributor converter from rywire. and I was just wondering if it bolts right on to the b18b1 block.
Old Jan 7, 2006 | 03:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: distributor (SupraRXZ)
I think OBDII distributors had extra sensors (TDC, CKP, and CYP) to detect misfires. The ODB0 doesn't have all of those.
Old Jan 7, 2006 | 05:45 PM
SupraRXZ's Avatar
Default Re: distributor (Dogginator)
well converting everything to obd1 but i dont got a lot of $$$ so ya thats y i was wondering
Old Jan 7, 2006 | 07:47 PM
rdeezy78's Avatar
u will need an obd-1 ecu also. i'm not sure if u mentioned that already. Also, i do think the distributor will bolt on, but will not work correctly because u will have an obd-1 ecu. I'm in the middle of mine as we speak. So i'll let u know how it turns out. I'm waiting on rywire to send my harness for the distributor. Good luck
Old Jan 8, 2006 | 10:37 AM
SupraRXZ's Avatar
Default Re: distributor (rdeezy78)
ya i have everything for the obd1 coversion execpt the distributor. If it doesnt work since its a obd0 why would rywire make a coversion adapter to make it plug right in to a obd1 plug?
7rrivera7
May 14, 2014 03:25 AM
viking-101
10
Feb 22, 2012 01:46 PM
kylesmith3251
Jan 18, 2009 01:52 PM
kylesmith3251
Jan 17, 2009 05:47 PM
SikAuto
Dec 28, 2008 12:58 AM
