o2 sensors
Old Feb 12, 2004 | 05:37 PM
streetstylenperformance's Avatar
Default o2 sensors
so how do I go about this? I'm trying to get my p28 to run. My hx is wired with a 5 wire and a four wire. I can't figure out which wire the p28 reads because I can't find a replacement 5 wire to plug in to see if the stock ecu clears code with a new 5 wire becasue the only five wire I can find costs $400. Do I need to re-wire or is there a way to by-pass and make the #2 4 wire port the main port.
Modified by streetstylenperformance at 6:52 PM 2/12/2004
Old Feb 12, 2004 | 06:00 PM
Default Re: o2 sensors (streetstylenperformance)
guru's anyone this is driving me nuts
Old Feb 12, 2004 | 06:21 PM
hondatim's Avatar
the p28 doesn't have capability to read the 5 wire O2 sensor. you will need to pin out and run a regular 4 wire O2.
Old Feb 12, 2004 | 06:28 PM
Default Re: o2 sensors (hondatim)
can you explain the pin out prossess or show a diagram or pic. I don't have much experience with this, but am eager to learn how to fix it. If you have a web site that explains this topic that would be cool, too. thank you for your help!!!!!!!!!!
Modified by streetstylenperformance at 7:53 PM 2/12/2004
Old Feb 12, 2004 | 09:28 PM
what is pin out? help?????? and does this mean I have to re-wire?
Old Feb 15, 2004 | 05:30 PM
hondatim's Avatar
'pinning out' refers to moving, deleting, or adding wires to ECU connector in order to add circuits or remove them from the ECU. I don't particularly have any schematics on line but you may want to PM 'Katman' here on h-t and he can direct you to what you need online. it's isn't that hard to 'pin out' the ECU for the 4 wire O2.
Good luck
Sorry it took me so long to post a reply...
Fortunately, we've been extremely swamped here at our shop in KC, so haven't had much time for tech support.
Old Feb 22, 2004 | 09:37 PM
I think I have figured it out I ordered a generic chip to fill the socket on my ecu and should have it by tomorrow, then I will splice it see what happens next!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
si0385.
13
Sep 22, 2006 06:58 PM
BROKE.eg
Aug 5, 2005 05:02 PM
Feb 28, 2004 08:25 PM
egizzle8
Feb 16, 2004 10:09 AM
Feb 8, 2004 04:22 PM
