O2 sensor help
Old Jun 30, 2002 | 05:42 PM
maxxdout's Avatar
Default O2 sensor help
i am fearing that my O2 sensor isn't working correctly anymore or that its broken. I have been repeatedly getting check engine lights and a "code 1" from the ecu.. I also have noticed a difference in fuel consumption of 80+ miles per tank.
Is there a way to test the sensor itself? Or do i have no choice but to replace??
TIA
Old Jun 30, 2002 | 07:37 PM
maxxdout's Avatar
Default Re: O2 sensor help (maxxdout)
anyone??????
From what i have read there is a way to test for voltage flux. Anything between .2 and .8 rapidly changeing indicates a functional sensor. However anything different, or not changing at all indicates failure.
Anyone heard this before???
Old Jul 1, 2002 | 05:56 AM
EE_Chris's Avatar
Well, the rate of oscillation is also important. I had about 100k miles on my stock O2 before it started heading south. I had the same symptoms as you....gas mileage decrease...unpredictable 'power'. Using an O'scope, I took a look at the O2 and saw that it was slow in response along with being slow to rich/lean tests.
Replaced it....everything was back to normal.
Old Jul 1, 2002 | 11:11 AM
maxxdout's Avatar
Default Re: O2 sensor help (EE_Chris)
dont have an o scope, but mulitmeter i do have. As far as replacement, where and how much??
Old Jul 2, 2002 | 01:09 PM
hondaeg5's Avatar
[quote]i am fearing that my O2 sensor isn't working correctly anymore or that its broken. I have been repeatedly getting check engine lights and a "code 1" from the ecu.. I also have noticed a difference in fuel consumption of 80+ miles per tank.
what car do you have?
[Modified by hondaeg5, 10:10 PM 7/2/2002]
[Modified by hondaeg5, 10:11 PM 7/2/2002]
Old Jul 2, 2002 | 02:20 PM
Mikey3000's Avatar
you can test it with your multimeter by checking the resistance between two of the terminals on the 4 plug connector of the O2 sensor. i don't remember what that resistance should be or what 2 terminals you should do it across but it says in the Helms.
Old Jul 8, 2002 | 01:30 PM
maxxdout's Avatar
Default Re: O2 sensor help (hondaef5)
my bad dude, 94LS
Old Jul 8, 2002 | 01:31 PM
maxxdout's Avatar
Default Re: O2 sensor help (Boss Hogg)
thanks for in help so far.....anyone else have experences with this problem???
yeegsr
Oct 28, 2004 06:19 PM
honda89
Sep 28, 2004 08:19 PM
Achenar
Apr 18, 2004 02:06 AM
GSRacer
Oct 8, 2001 06:59 AM
