o2 sensor?
Old Oct 8, 2001 | 08:50 AM
clean's Avatar
New User
Default o2 sensor?
how do i know if my o2 sensor is fried? i have a 97 ex turbo and i think the rich running engine burnt it out, but not sure. can you help? and how bout my MAP sensor too, it idles funny now, between 1k and 2k up and down
Old Oct 8, 2001 | 10:44 AM
88_SC_CRX_Si's Avatar
New User
Default Re: o2 sensor? (clean)
Check you ECU for any kind of codes. You should be getting a Code 1 from a bad O2 sensor.
In most cases MAP sensors do not go bad. It's usually a vacuum line or something else.
When was the last time you checked your coolant? Air will get trapped in there causeing a revving idle. So make sure it's good and bleed.
Another, is your idle could be out of spec. Try resetting your idle by pulling the EACV while it's running, and check your tech to see if it's in spec. If not, readjust it. Then kill the engine, and reset your ECU, and plug the EACV connector back in. Let it idle for a few minutes without giving it gas.
Old Oct 8, 2001 | 10:54 AM
976's Avatar
976
New User
Default Re: o2 sensor? (88_SC_CRX_Si)
http://www.hondata.com/techecucodes.html
Old Oct 8, 2001 | 02:02 PM
Mr. Choi's Avatar
New User
check for any trouble codes the ECU might throw at you. i had a similar problem and it was the TPS sensor, that might be the problem for you too.
Old Oct 8, 2001 | 04:20 PM
CardDealer's Avatar
Banned
Default Re: o2 sensor? (Chois i-VTEC)
Modified by CardDealer at 4:23 AM 11/16/2006
clowery89
Nov 8, 2010 03:02 PM
kHoA DoGG
26
Dec 28, 2002 09:14 AM
kHoA DoGG
Nov 20, 2002 05:25 PM
See Are X
Sep 5, 2002 07:40 PM
