idle problem when at normal temp
Old Sep 18, 2010 | 06:13 PM
clowery89's Avatar
Default idle problem when at normal temp
it runs nice when cold but when warmed up if i come to a stop it will want to die or will die
Old Sep 18, 2010 | 10:53 PM
DicerYuri's Avatar
Default Re: idle problem when at normal temp
mine does close to the same, it just idles with the rpms pegged at 0 =(
Old Sep 19, 2010 | 06:36 AM
clowery89's Avatar
someone said it could be my map sensor or TPS
Old Sep 19, 2010 | 07:58 AM
clowery89's Avatar
i did the ecm codes with that jumper wire and got code 1 it say O2 sensor
Old Sep 19, 2010 | 09:06 AM
nus_dogg's Avatar
Have you clean your IACV? Thats what controls the idle.
Old Sep 19, 2010 | 09:12 AM
poorman212's Avatar
First off I can only guess you've got an Accord somewhere between 90 and 95 ish..some of the 96's went ODB II.
If you got a bad O2 sensor then I would start there. It could be that with the bad O2 is causing the issue (too rich or too lean). Then there is another list of things to check.
Old Sep 19, 2010 | 09:13 AM
clowery89's Avatar
well see when i did the head work anything i took off i cleaned and i cleaned it and thats about the time it all started idleing bad so i dont know ill ook at it
Old Sep 19, 2010 | 09:14 AM
clowery89's Avatar
mine is a 96 accord F22B2
Old Sep 19, 2010 | 12:29 PM
DicerYuri's Avatar
make sure to have a volt omiter
cause ive swaped out 2 onto my car, but they where both sketchy. i had them from a nother car. let me know if that O2 sensor works, are o2 sensors interchangeable from d to b series? cause i am swapping soon but want my d to run good when i sell it
Old Sep 19, 2010 | 02:18 PM
clowery89's Avatar
im sure they do i just got home from pic a part and i was talking to a guy that was getting stuff from a b16 i think it was and he said they are
Old Sep 19, 2010 | 02:19 PM
clowery89's Avatar
oh just changed the map and it didnt help so now im gonna try the throdle body cause i just picked up one with a tps
Old Sep 19, 2010 | 02:27 PM
DicerYuri's Avatar
sweet let me know how that goes for yeah, i hate to toss a lot of money into my D if i am going B soon
Old Sep 19, 2010 | 02:45 PM
clowery89's Avatar
yeah i understand ill be back in afew gonna change it now that the car has cooled off
Old Sep 19, 2010 | 03:33 PM
clowery89's Avatar
ok the body didnt help next and last thing i have to try before i rule for the O2 sensor .....and that is the IACV
Old Sep 19, 2010 | 04:24 PM
DicerYuri's Avatar
ok sweet, good luck on that, i dont know if its needed but i used electrical connection cleaner.. i did one iacv with carb and one with the EC
soo i was at a loss
Old Sep 19, 2010 | 04:36 PM
clowery89's Avatar
well i just replaced the IACV and it still died but the diffrence is i could hold my foot one spot and it would not die before if i held it it would still wanna die
Old Sep 19, 2010 | 04:44 PM
Bwill9886's Avatar
When you installed it, did you make sure the TPS voltage is within proper spec?
Idle voltage: 0.40-0.50
WOT voltage: 4.5-5.0
If it is not within this range you WILL have the exact issue you described in the first place (more so for the idle voltage). Just replacing the TPS will not guarantee anything.
Old Sep 19, 2010 | 05:12 PM
clowery89's Avatar
WOT = Wide Open Throtle?
Old Sep 19, 2010 | 05:42 PM
DicerYuri's Avatar
i recleaned and swapped out my iacv still same stuff as soon as the fan kicks on and i touch the throttle it drops to 0 rpms. and it seems to be starting hard like 2 cycles and it sounds like its tripping over it self aka too much gas and then it starts... who knows. hoping an O2 sensor cures your issue, and possible mine
Old Sep 19, 2010 | 06:10 PM
clowery89's Avatar
well i just replaced my head gasket and thats what mine was doing when i went to start it.... come to find out that coolent was getting into two of the cyls when the car was off then had to burn it out at the start up
Old Sep 19, 2010 | 06:37 PM
DicerYuri's Avatar
ohh on the start up? did that fix the idle? or just the start up issue?
Old Sep 19, 2010 | 07:46 PM
clowery89's Avatar
well the car idled fine before i changed the head gasket but i clean stuff with carb cleaner and i guess it messed up my IACV ..... so IACV fixed Idle.... and head gasket fixed start up
Old Sep 19, 2010 | 08:43 PM
Bwill9886's Avatar
Yes. Sounds like you may have fixed the problem though?
Old Sep 20, 2010 | 08:53 AM
clowery89's Avatar
well kinda just got in the car to drive today and it drove good then after a while started to idle down wanted to die unless i gave it gas
Old Sep 20, 2010 | 02:55 PM
DicerYuri's Avatar
so the iacv helped some but didnt cure your issue?
