is this normal after disconnecting the battery?
Old Nov 19, 2002 | 08:17 PM
_Endless_'s Avatar
Default is this normal after disconnecting the battery?
everytime i disconnected the battery to work on something, the idling always dips to zero and near stalling and sometimes it just stall. like yesterday, i disconnected the battery to put in the power wire of the sound system, and it was like only about 10 mins then each time i have to stop, i step on the clutch the rpm dips to 0 and then come back up to about 550 rpm then slowly came back to normal idling. is honda ecu really that sensitive? or is there something wrong with my car? it's not funny anymore.
Old Nov 19, 2002 | 08:47 PM
DA MUGEN 1's Avatar
Default Re: is this normal after disconnecting the battery? (_Endless_)
Sounds to me like you have a weak alternator
Old Nov 19, 2002 | 08:55 PM
_Endless_'s Avatar
Default Re: is this normal after disconnecting the battery? (DA MUGEN 1)
does the alternator have anything to do with it? in what way?
anymore?
Old Nov 19, 2002 | 09:23 PM
flip b18b's Avatar
yeah it sounds like your not charging enough
Old Nov 19, 2002 | 09:24 PM
oldsun's Avatar
first way are you working on a started car!
second the battery only starts a car, the alt is what keeps it running (hence why most race car have no battery on board)
the alt also chareges the battery while the cars running disconnect the battery and you can destroy your alt so as in the first why are you working on a car that is started.
Old Nov 19, 2002 | 09:35 PM
b19coupe's Avatar
Default Re: is this normal after disconnecting the battery? (oldsun)
OBD2 Acura ECU's "learn how to idle". When you disconnect the battery, you erase the ECU's memory. It has to relearn how to idle properly-the service manual says to let the engine idle for 10-15 minutes in order for the ECU to relearn the idle.
Old Nov 19, 2002 | 10:25 PM
_Endless_'s Avatar
Default Re: is this normal after disconnecting the battery? (b19coupe)
sorry if i wasn't clear enough, i didn't work on the car nor disconnected the battery while the engine is running.
i don't know if there's something wrong with my car coz like i've posted, WHENEVER i disconnected the battery(engine OFF) for about 10mins to work on something, like recently i just connected the + wire of the stereo system to the battery then i started the car and drive around, the rpm just dips whenever i step on the clutch to make a complete stop. this is the first time i encounter such thing so i don't know if it's normal or not or maybe honda's ecu is a bit sensitive.
any ideas??
Old Nov 19, 2002 | 11:03 PM
T25 civic's Avatar
After you disconect the battery you should start the car without the stereo on, without the a/c or heat on, no headlights nothing. No power drawl off the battery. Let the car sit and idle for 15 minutes then take it out for a spin. The ECU needs to "relearn" how to idle.
Nick
Old Nov 19, 2002 | 11:57 PM
CivicVTi182's Avatar
Default Re: is this normal after disconnecting the battery? (T25 civic)
maybe check your BACKUP or ECU ( usually 15 amps ) fuse, if it's dead it will erase ECU's data every time you disconnect the battery
Old Nov 20, 2002 | 08:26 PM
DA MUGEN 1's Avatar
Default Re: is this normal after disconnecting the battery? (CivicVTi182)
Ok now that we have gotten it straight that you DID NOT have your car running when you disconnected your battery,Do you have a amplifier for your stereo and how much power is it drawing from you battery/alternator
Old Nov 20, 2002 | 09:42 PM
Nameless RB26's Avatar
If you are concerned about the charging system (I would be), take it to a mechanic and have him test the charging system output. I would test the battery too.
Old Nov 20, 2002 | 10:41 PM
_Endless_'s Avatar
Default Re: is this normal after disconnecting the battery? (Nameless)
the battery is new. it's only 4 months old.
ALLDAY-24
18
May 3, 2011 08:25 AM
eazy64
15
Nov 11, 2010 08:53 PM
young3bro
23
Dec 6, 2007 07:48 AM
mjrage
18
Jun 25, 2004 06:28 PM
illusion
Apr 3, 2002 11:08 AM
