noob question:clearance
Old Apr 13, 2009 | 01:18 PM
xander1100's Avatar
Default noob question:clearance
when talking about piston to wall clearance, is the measurement from the piston itself or is it the rings everyone is talking about. i.e. having a piston clearance of .0035", etc. or does everyone get pistons custom made to that size? or is that already factored in by the company so when you get pistons for a 81.5mm bore they already have the .00whatever taken out of them?
sorry did a search but could find much to explain it
Old Apr 13, 2009 | 02:39 PM
srmofo's Avatar
Default Re: noob question:clearance
you buy your pistons for whatever bore you want, then the machine shop bores and/or hones the sleeves to the proper size to achieve the P2W clearance that you want. Some go about this backwards and measure the cylinder, figure out what it will take to clean them up and then buy the piston of the proper diameter....it really kinda depends on your situation. If you are buying a sleeved block then you have the option to make it whatever you want. If you are reusing a block then you are limited to what the bore already is and what it will take to clean the cylinders up, and the max amount power the stock sleeves will handle
P2W is the cylinder diameter minus the piston diameter divided by 2, since there is 2 P2W gaps, one on each side of the piston
ring gap is just that. it is the gap in between the ends of the rings
Old Apr 13, 2009 | 03:17 PM
xander1100's Avatar
cool, couldnt of asked for a clearer answer
xjdmjunkiex
Feb 28, 2011 08:26 PM
user 98292739
Aug 15, 2009 07:26 PM
Yambor
Apr 29, 2005 10:55 PM
turboex
Mar 1, 2004 11:11 AM
B pwr
Mar 26, 2003 10:44 AM
