non-firing injectors...??????????????????
Old Dec 11, 2002 | 02:46 PM
digglewitz's Avatar
Default non-firing injectors...??????????????????
im tryin to figure out why my injectors arent firing.....inhave a 91 b18a and it ran in the car i have it in.....all of a sudden it would just spin and spin and spin....i would like to know if anyone knows EXACTLY what would cause the injectors not to fire.....i swapped out the distributor....not knowing if either works now though....it will however start on ether....but then just stalls out....if you can help please do.....thank you
Old Dec 11, 2002 | 02:52 PM
JPX's Avatar
JPX
Default Re: non-firing injectors...?????????????????? (digglewitz)
Check the driver circuit(resistor block) and ground wires on the injector harness.
Old Dec 11, 2002 | 04:53 PM
Shawn C's Avatar
In The Garage
Default Re: non-firing injectors...?????????????????? (JPX)
yeah and check for voltages and grounds at the injector wires. also check all cylinders for a spark.
Old Dec 11, 2002 | 05:10 PM
RaceTilIDie's Avatar
Default Re: non-firing injectors...?????????????????? (22lbGS-R)
Check the main relay and the injector resistors.
Old Dec 11, 2002 | 05:11 PM
digglewitz's Avatar
you know where to locate the resistor block???????? cause i cant find it.....and im gettin mixed reviews on it even existing
Old Dec 11, 2002 | 06:19 PM
You can get a Noid Light at Pep Boys for about $3-4 to test for voltage pulse, might help.
Old Dec 11, 2002 | 11:11 PM
dr650's Avatar
New User
Default Re: non-firing injectors...?????????????????? (RaceTilIDie)
did u put the ground for the injectors?it should be on thermostst housing.
for sale!!!
bay area only<<<pick-up only<<i got this following stuff for sale:
92 ls motor /trany/ecu for $600 (rebuild motor trany no grinds)
93 prelude motor/trany/ecu for $1000(h23)(motor has 148000 mlz/trany no grind/still good compresion/needs water pump)
95 si trany for $200(no grinds)
92 ys1 trany for $400(da gsr)no grinds
92 integra trany for $200(no grinds)
94 si motor for $250(100000+ mlz)needs head gasket
pwo ecu for $100
cr/vtec motor for $1600. still in the car.no leaks.(b16 head /jdm b20z)
91 integra ls for sale >>$2500 210000+mls.
Jordan Bishop
15
Mar 30, 2018 09:07 AM
JDM C.A.R
13
May 10, 2010 07:30 AM
dayl
21
Apr 13, 2010 08:06 PM
jdmek2277
10
Nov 18, 2007 04:34 AM
AndyD
Mar 17, 2005 06:06 AM
