injectors??????
injectors??????
does anyone know what are the colors of the injectors in order facing your car from the front and starting with your left hand as the first one for a d15b.
thanks
thanks
Re: injectors??????
injector colors? thats something new to me. i was always under the impression that injector firing order was irrelevant and were colorless
Re: injectors??????
the injector firing order is definitely extremely important
op: i assume you want to know the wire colors.. i however don't know what they'd be. assuming your harness isn't in shreds it should be obvious which wires go with which injector though..
Re: injectors??????
honestly to me that makes no sense. maybe i know less than i think (very possible) but as long as the injectors are the same (240cc 310cc 550cc etc) the order they are placed on the fuel rail doesnt matter. the injector clips should only be able to reach one injector and can only fit into the intake manifold one way. maybe we have a mis communication issue here???
Re: injectors??????
yea we sure do lol. when you say firing order that makes me think the order in which the injectors are firing.. not the order in which they are placed in the fuel rail. injector firing order is important, any given injectors placement on the rail is not.
Re: injectors??????
well theres to answers whom should i beleive.lol i dont know if its comment sence since the wireing on the 4 injectors are different colors its because they were ment to be in a properly order if not what was the whole point of them being different. would the car even start if the injectors are mist place since your saying injector firing is important.?
Re: injectors??????
depending on how muffed up the wiring is the car might kind of run or it may not run at all. since you seem unsure of which wire goes to which injector position i would suggest that you use a multimeter and do a continuity test to figure out which wire is going to which injector position (a1,a2,a3,a5) at the ecu.
Re: injectors??????
if you are saying that you have different color injectors, then its possible that they have been replaced one or two at a time. junk yard cars and new ones from autozne could all be different colors depending on the aftermarket manufacturers prefrence and cars they came off of. they should have all been replaced at the same time with new ones IMO. if you mean somehing different than individual injector colors then obviously i'm lost. i just woke up LOL still got my full cup of coffee
RICE POLICE SIP
02-13-2010 10:01 AM
