noisy cam gears
Re: noisy cam gears (da_rockwilda)
I did run into this on a set of AEM adjustables and it turned out that the cam gears were hitting the plastic rear timing cover slightly. Nothing a razor blade couldn't fix. Determine where the noise is coming from.
Re: noisy cam gears (Jared)
damn taht was quick. its definitely coming from the cam gears, but it doesnt seem to hit the plastic cover(i cut a portion of it off to show the gears, but the valve cover is still uncut) thanks for the reply
