no vtec, tried EVERYTHING...still nothing
Old Oct 17, 2007 | 02:35 AM
AdamB18C1EK's Avatar
Default no vtec, tried EVERYTHING...still nothing
hello all. im posting here as sort of a last ditch effort. so ill start off with the basics...i have a 98 cx hatch with a 98 ex harness...so there has been nothing hacked up. h2b swap...everything should be electrically sound. moving on. i changed heads on my h22 to one that wasnt milled just a stock head...replaced the o-ring under the cam cap along with the little plunger dealy thing...along with the ones that go further up towards the cam gears. ive changed vtec solenoids. ohm'd out the wiring...all good. no CELs. no blown fuses...alternator and battery both charging fine. have great oil pressure. uhhhhhm. i guess thats pretty much it. everything else is working perfectly normal. im running a chipped p30 tuned on uberdata. thanks in advance ......P.S. havnt tried swapping ecus yet. but will do so today
Old Oct 17, 2007 | 08:22 AM
h22crxpwr's Avatar
Default Re: no vtec, tried EVERYTHING...still nothing (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote">hello all. im posting here as sort of a last ditch effort. so ill start off with the basics...i have a 98 cx hatch with a 98 ex harness...so there has been nothing hacked up. h2b swap...everything should be electrically sound. moving on. i changed heads on my h22 to one that wasnt milled just a stock head...replaced the o-ring under the cam cap along with the little plunger dealy thing...along with the ones that go further up towards the cam gears. ive changed vtec solenoids. ohm'd out the wiring...all good. no CELs. no blown fuses...alternator and battery both charging fine. have great oil pressure. uhhhhhm. i guess thats pretty much it. everything else is working perfectly normal. im running a chipped p30 tuned on uberdata. thanks in advance ......P.S. havnt tried swapping ecus yet. but will do so today </TD></TR></TABLE>
ur probably missing one of the pins in the rocker assmbly. happened to me. take out the cams and look at each one of the rockers to make sure the pins are all in there.
D-Rob
Engine Management and Tuning
Apr 14, 2008 11:39 PM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
AdamB18C1EK
17
Oct 19, 2007 01:30 PM
Simple SOHC
Aug 29, 2004 08:46 PM
Nothing.Special
15
Jul 14, 2003 11:04 AM
