NO VTEC. ........Need help asap Please.
Old Oct 21, 2008 | 12:08 PM
  #26
kennyc2189's Avatar
Default Re: (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">you are missing an o-ring in the center of the head where the cam cap goes.</TD></TR></TABLE>
x4 haha
Old Oct 22, 2008 | 12:13 PM
  #27
HitF8's Avatar
Default Re: (rd91sib18c5r)
x4
Old Oct 22, 2008 | 01:55 PM
  #28
CarbonizedDX's Avatar
Default Re: (DonF)
notice in the upper right corner there is the letter shape of "up", this is the correct orintation, if it was on the other side and read "qu" it'd be wrong.... I dunnot bout the rest but this is someting I know for sure...
Old Oct 22, 2008 | 04:56 PM
  #29
91' LS-VTEC's Avatar
Default Re: (CarbonizedDX)
Well in that pic it look like it says dn. So is this wrong. Can the UP be placed in the right corner?
We where having a oil leak from this HG.
Enough to where the long slot/tray in the top right corner of the block, would fill up after driving it around..
Old Oct 22, 2008 | 05:39 PM
  #30
kennyc2189's Avatar
Default Re: (91' LS-VTEC)
its on right if u put it ne other way it wouldnt read up but she looks like it is getting plenty of fuel
Old Oct 22, 2008 | 05:58 PM
  #31
Default Re: (kennyc2189)
actully , looking at it again. If i turn it, the UP would be in the left lower corner, and the 2 holes in the top center. One would be coverd.
Also Looking @ the new HG. That same "up" isn't stamped into the HG. Both HG are OEM HG.
Old Oct 22, 2008 | 10:50 PM
  #32
UP is uses as the orentation of the headgasket in which side meets the head and which side meets the block. While YES the pic shows dn, if you look at it from the firewall side of the car it will say UP.... The two oil pressure lines in the middle of the block on the intake side mean the gasket can only be placed in that direction other wise you've got a covered whole and a gasket sticking out into noting...
I'd check to see how level/flat the head and block are.
Old Oct 31, 2008 | 11:59 AM
  #33
jeffsciv23's Avatar
any updates cesar?
Old Oct 31, 2008 | 07:19 PM
  #34
Default Re: (jeffsciv23)
no, Kukes took a week off to go Elk hunting. He should be back this weekend. Then back to working on th ecar again.
You can come down and help put it back together. Since I don't rememebr where everything went.
Old Nov 1, 2008 | 09:24 AM
  #35
jeffsciv23's Avatar
whens he come back? i might head down
Old Nov 1, 2008 | 09:35 AM
  #36
Should be back tonight, if not. Sunday. I know he has to work monday. Once he gets here I'll let you know.
Old Nov 10, 2008 | 09:43 AM
  #37
Default Re: NO VTEC. ........Need help asap Please. (91' LS-VTEC)
well the parts guy @ Honda, tells us that there is no "o-ring" for that head?
WTF?
Old Nov 11, 2008 | 02:23 PM
  #38
d112crzy's Avatar
Honda is retarded, they can hardly ever find the right parts in their own system. You should be able to use any o-ring as long as it's the correct size.
Or [freak] it, use some good ole Honda Bond LOL!!
Who's tuning? Please tell me its Randy at Kaizen and not Sosa.
Old Nov 11, 2008 | 03:01 PM
  #39
98vtec's Avatar
moderator emeritus
Default Re: (d112crzy)
go to lowes and buy an o-ring assortment pack.
Old Nov 11, 2008 | 04:13 PM
  #40
Originally Posted by d112crzy
#11 is the one that is on #10 not on top.
Actulley, neither one of those 2. It will be Rick (speedz) that will do the street tune (NA). Once its boosted, he will do a base tune. The take it to Dave Lee.
Old Nov 11, 2008 | 04:27 PM
  #41
Here is what I'm talking about. When we order #10 & 11 this is what wee get.
witch is in the spot, where the o-ring should be.
SO.. I need another o-ring on top like this????? witch is the one they don't list @ Honda. Corrett?
Old Nov 11, 2008 | 06:12 PM
  #42
justa4banger's Avatar
mine did that but i dont remember if it was code 22 or 21 but either way my oilpan had a dent in it so there wasnt enough pressure bc of the dent
Old Nov 11, 2008 | 06:20 PM
  #43
Default Re: (justa4banger)
this one has a brand new Morosso oilpan & pick up. The motor has 90miles on it so far.
Maybe we should try a stock oilpan & pick up???
Old Nov 11, 2008 | 06:59 PM
  #44
that could be it too bc the motor pick up not be in the same spot as in the oil pan bc on mine iwas going to use an oil pan from a a6 for a z6 but they were in different spots
ps i know that the a6 isnt vtec but it still has and oil pick up(just putting that out there)
hope everything works out
Old Nov 13, 2008 | 03:47 PM
  #45
Old Nov 13, 2008 | 04:34 PM
  #46
d112crzy's Avatar
SI! I asked 98vtec and he said yes also.
Old Jan 15, 2009 | 08:00 PM
  #47
Default Bring this thread back.
So after a little winter break. We got back to putting the motor together.
So still NO VTEC, even after installing the "o-ring"
AND, there is still a oil leak comming from the headgasket.
any other answers? really hate pulling this damb head off, spending another $50 on another HG.
Old Jan 16, 2009 | 05:14 PM
  #48
LsV9kEz's Avatar
might have found your problem
Old Jan 17, 2009 | 09:00 AM
  #49
LsV9kEz's Avatar
nm... saw that you have an "h" i showed pic of a "b"
Old Jan 17, 2009 | 09:22 AM
  #50
did you try swapping the oil pans out and making sure there isnt any dents
