No power in VTEC, please help.
Old Sep 22, 2004 | 12:51 PM
bigmadjohn's Avatar
Default No power in VTEC, please help.
Dear All
A few days ago I put up a post saying that my car wouldnt do over 110. Things have got much worse. Ive got a stock (apart from a Blitz SUS air filter) UKDM B18C6 ITR. About a week ago i realised that when it hit VTEC in 5th, that it wouldnt rev any higher then 6k, VTEC is kicking in (or it sounds like it), but there is no power there, it will sit at 6k in VTEC for about 10 sec before dropping out of VTEC again. I also noticed a flat spot in 4th from 6k-7krpm, but today this got much worse. In every gear (including 1st) there is a noticeable lack of power, but in 1st-3rd it can still pull through it, in 4th and 5th it will not pull. The car drives perfectly out of VTEC, with no problems whatsover. A few months ago I had the rotor arm screw come loose, wrecking the arm and dizzy cap, I replaced the arm and cap, and the car felt OK, but VTEC was louder and less powerful. I dont have a timing light, so I didnt check or set the timing at this time. Im getting fed up of it, so next week im gonna book it into honda. If any of you have any ideas what this could be, please post, as im fresh out of ideas, ive checked oil level/quality, the VTEC seems to be engaging, so can I assume that the solenoids working???? If anyone has ANY ideas ill be most grateful.
Many Thanks
Rgds.
John
Old Oct 3, 2004 | 06:57 PM
oerski's Avatar
Default Re: No power in VTEC, please help. (bigmadjohn)
Bump, help mine is similer. sounds rather wails like its engaging but major powerloss.....?????
Old Oct 3, 2004 | 07:06 PM
93lsd's Avatar
what ecu are you using because some of the canadian and jap have a speed limiter right at 115 to about 120...
Old Oct 4, 2004 | 01:34 AM
Import-Style.de's Avatar
Just try to reset your ECU by disconnect the ECU, Hazard and Back-Up Fuse. When it doesn't work after that you have to load your stock ROM File from the ECU in a ROM EDITOR and look at the options for speed-limiter, vtec, rev-limiter...
delslow302
14
Mar 27, 2009 06:09 PM
civicsir2
Mar 6, 2009 10:30 AM
bigmadjohn
Sep 22, 2004 01:18 PM
aziz93
Sep 6, 2004 10:05 AM
JDM00SI
Aug 18, 2004 01:17 PM
