No Go on the hondata.
Old Nov 26, 2004 | 02:46 PM
dornon13's Avatar
Default No Go on the hondata.
Well heres the deal i bought a s200b system to run with my turbo setup, right now i dont have all my parts so i figured why not install the hodata and play with the 3-step and what not...so i went down to the shop and had our guy burn me a stock chip for my car and added 5% fuel across the board because i got an intake header and exhaust which should flow a hair better so why not...anyways i hook it all up and its idling at like 2500 rpm and throwin a CEL also i tried to give it a little gas and it kinda bogs unless you REALLY ease into it...the chip is installed the right way with the arrow/notch pointed towards the wiring harness, and the hondata unit does come on with a steady red light... any ideas?
Old Nov 26, 2004 | 03:11 PM
PyroProblem's Avatar
Default Re: No Go on the hondata. (dornon13)
whats the code its throwing?
FP set right?
Old Nov 26, 2004 | 03:25 PM
dornon13's Avatar
Default Re: No Go on the hondata. (PyroProblem)
I dunno how to check the code.. and whats FP? fuel pressure?...
Old Nov 29, 2004 | 02:55 PM
99lsvtecauto's Avatar
check the code like u would normally thru the service connecter right passenger side kick panel u have 2 jumper it put key in turn key one don't start the car the light should flash hondata only has 10 codes that it throws should not be that many
em1tetus
Jul 16, 2014 09:05 PM
ef2hondaboi
Jul 21, 2009 06:42 PM
Thateguhate
Apr 27, 2007 03:01 PM
tecnic1
Nov 25, 2006 07:36 AM
GWInquisitor14
Mar 12, 2005 12:02 PM
