Hondata S200 Issue
Old Apr 25, 2007 | 06:02 PM
Thateguhate's Avatar
Default Hondata S200 Issue
Quick question.. Im running a Mildly built LSvtec on this program and its an obd2>obd1 with a p28.
Problem is for some reason I keep throwing a CEL with no code behind it.. The 02 is disabled and loop is closed. Usually it will turn on about 10-15 mins after driving and if I turn the car off and back on its cleared.
any ideas?? I posted on the hondata forum but didnt get very far. Im not sure if its the hondata itself or if its in my wiring harness somewhere?? Thanks in advance.
Old Apr 26, 2007 | 05:45 AM
Default Re: Hondata S200 Issue (Doughboy63)
..........sigh
Old Apr 26, 2007 | 02:53 PM
Spunkster's Avatar
You need to check the error code while it is still there. Checking it after you have turned hte car off and back on will have cleared the code.
Old Apr 26, 2007 | 04:49 PM
Default Re: Hondata S200 Issue (Spunkster)
Ive checked it while the car is on. Still the same thing.. Both ways gave the same result.
Old Apr 26, 2007 | 05:06 PM
NJIN BUILDR's Avatar
If the chip was burned with an older version of romeditor it can happen.You will probably find the cel is an o2 error even if it is disabled.Have someone burn the chip with a later version and it should go away.
Old Apr 26, 2007 | 06:47 PM
Default Re: Hondata S200 Issue (NJIN BUILDR)
coolio! Thats what im pulling for, heading to my tuner in a couple days.
The wierd thing is it feels like its either scheduled when it turns on, or happens in certain areas of my drive to work and back. Even though I know its not the reasoning.
I'll keep you guys posted!
Old Apr 27, 2007 | 03:01 PM
Spunkster's Avatar
you need to check the code using datalogging....not the jumper method.
Zaraki
Engine Management and Tuning
Oct 28, 2013 07:17 PM
LSV_REX
Aug 6, 2008 09:06 AM
turbolsintegra26
Mar 24, 2004 11:55 AM
FOrSfEd
Nov 16, 2003 03:09 PM
seek167
Jul 1, 2002 03:48 AM
