new Z6 build
Old Jan 4, 2007 | 09:37 PM
HCivExoo's Avatar
Default new Z6 build
nothing outrageuos bbut wanted to know if/ what you'll thought about it.
Z6 block, scat rods ratted upto 650hp, don't quit know what pistons yet, but for sure 75.5 mm bore, 9.0/1 compratio. Ballanced everything, acl bearings, cometic head gasket, block gaurd. Have to get the desktop dyno software for the head but thinking about 1mm oversized valves just on the exhaust side, but still a good 3 angle valve job on the intake side, and more on the exhaust.
Don't know what i would like to do withthe combustion chambers???
equal length tubular maunifold, turbo system not designed/researched enough yet
13-15 psi
9000 RPM
i know the turbo is a big variable but i want somethign that spools up quick where i can put this motor in a track car for a little autocross and drag strip.
ohh tranny nothing special driveshaftshop axles, and some lsd, but can't afford quife.
Old Jan 5, 2007 | 07:09 PM
HCivExoo's Avatar
Default Re: new Z6 build (HCivExoo)
bumb
Old Jan 6, 2007 | 07:45 AM
HCivExoo's Avatar
bumb come on i really want to know what you guys think
Old Jan 6, 2007 | 06:39 PM
91SiZ6's Avatar
13-15psi on a stock DSM turbo or a GT35? That's a pretty big variable. What's your horsepower goal? Start there with what you want to do the head and for picking your turbo.
Old Jan 7, 2007 | 06:53 PM
HCivExoo's Avatar
Default Re: (91SiZ6)
i haven't done the research on a turbo yet. I was thinking t3/t4 ??deffinetly want something that makes full boost as low *** possible, thats why i am only thinking about 13-15 psi?
not looking for huge power numbers, maybe low to mid 200 range.
Old Jan 7, 2007 | 10:47 PM
91SiZ6's Avatar
GT28R dude. That's the turbo you want.
Old Jan 10, 2007 | 06:46 PM
HCivExoo's Avatar
just got dyno software for labtop, will mess around with turbos and valve sizes to see what i get. something up with the software cause i can't set the right bore, rod stroke combo without the software messing up??
i was looking at that turbo last night and thought it would work well.
thanks for input
Old Jan 11, 2007 | 01:12 AM
91SiZ6's Avatar
Did you get a dyno simulation? If so, which one?
1989civicef
Feb 13, 2015 01:02 PM
97_ek_coupe
Sep 25, 2012 06:36 AM
D15b Sol
May 13, 2010 01:48 PM
memorybox
Sep 24, 2006 08:51 PM
chippy
Dec 2, 2004 02:20 PM
