New head on engine -> timing problems i think
Old Jun 18, 2002 | 07:15 PM
Rocket SLC's Avatar
Default New head on engine -> timing problems i think
Ok, first time poster here. I put a "Gude" racing head. On my brothers '94 Integra(B18B1). Lets just say that its not running so well after the install. Kinda sounds like a go-cart when you rev it up. I checked the timing over and over and i still think its right on. Everything seems to line up. What could i have messed up in the process? Before i started the tear down, i put the engine at TDC (cams pointing up and away from each other, the rotor was pointing twards #1 cyl. I have no manuals for this car at all and i just want to check with you guys to see i you can offer any suggestions. Did i miss something or what? Hopefully its something easy.
Old Jun 18, 2002 | 07:54 PM
Jared's Avatar
Default Re: New head on engine -> timing problems i think (Rocket SLC)
The crank pulley has four marks on it, three right together and one out from them by itself. The one out by itself is TDC when lined up with the gunsight. Also at TDC on #1, the cam gear "UP" arrows will point up and the lines that are on the right of the exhaust cam and left of the intake cam will line up with each other.
Old Jun 18, 2002 | 07:59 PM
BreakStuff's Avatar
New User
Does it idle OK and sound like ****?..
or does it idle rough and sound like ****?....
Old Jun 18, 2002 | 08:30 PM
Rocket SLC's Avatar
Default Re: New head on engine -> timing problems i think (BreakStuff)
it barly idles, at like 1-200 RPMs, and runs like ****. it does start and run though. just really rough. I have to keep my foot on the gas. and it blows mad smoke out the exhaust.
Old Jun 18, 2002 | 08:36 PM
MikeSarr_GSR's Avatar
Check the index mark on the cams and make sure the #1 piston
is at TDC... this is the white mark on the crankpulley... you might
have missed that step and bent valves man... hate to break it to ya
[Modified by MikeSarr_GSR, 5:37 AM 6/19/2002]
Old Jun 19, 2002 | 04:18 AM
Rocket SLC's Avatar
Default Re: New head on engine -> timing problems i think (MikeSarr_GSR)
i dont think so, the mark on the crank is lined up and the cams are pointing straight up, also the little holes are lined up. I turned the engine over many times with a wrench before i fired it and there was no interference.
Old Jun 19, 2002 | 05:44 AM
88_SC_CRX_Si's Avatar
New User
Could a ground wire not be grounding...
Old Jun 19, 2002 | 06:11 AM
Rocket SLC's Avatar
Default Re: New head on engine -> timing problems i think (88_SC_CRX_Si)
I think i only took off the one ground strap from the valve cover to the front radiator support. How would that effect the performance?
-Also, who makes a good repair manual for this car? How much do they run?
Thanks
Old Jun 19, 2002 | 06:13 AM
jetdriven's Avatar
helms is the only repair manual worth a crap. I found out the hard way getting the exhaust cam off a tooth. use that
Old Jun 20, 2002 | 08:53 AM
Rocket SLC's Avatar
What would happen if i had the dist rotor upside down? Would it still run?
Old Jun 20, 2002 | 11:43 AM
Mikey3000's Avatar
you can't put a dist. rotor on the wrong way. it only goes on 1 way. you could install the distributor 180 degrees off, but i don't think the car would run if you did that.
Old Jun 20, 2002 | 12:49 PM
kkim's Avatar
Default Re: New head on engine -> timing problems i think (Boss Hogg)
double check the plug wires to the dist. for proper firing order.
Old Jun 21, 2002 | 09:21 AM
Rocket SLC's Avatar
Default Re: New head on engine -> timing problems i think (kkim)
Ill check the firing order again but i dont think that they moved aroun to much durring the swap. I wish you guys could hear it run. That would help im sure.
Thanks again.
Old Jun 21, 2002 | 09:55 AM
Gerst240's Avatar
actually if you put the rotor 180 off it would run but it would run like total **** kinda sound like a tractor that kinda sounds like whats goin on here
Freemananana
Sep 17, 2015 03:43 PM
hybrid98
Jun 26, 2007 08:57 AM
Hoosier Daddy
Oct 12, 2003 06:29 PM
sshaikh01
Apr 28, 2003 03:18 PM
sporkcrx
Sep 24, 2002 07:51 PM
