Need some info on my build ls/vtec
I just got a GSR block, the crank is screwed. i can get a deal on a ls crank, typeR pistons&cams, and a GSR head.my question...
im gonna use a ls crank/rods in the gsr block w/ the gsr head/pistons...makes it basically a gsr but the stroke is longer so is the compression that of a stock gsr or....?
same setup as above with typeR pistions,compression??
is there anything special that i need/need to know to accomplish this build?
