GSR crank in LSVtec ? (searched)
Old Feb 6, 2003 | 01:34 AM
5 Skware's Avatar
I missed the boat
Default GSR crank in LSVtec ? (searched)
I was wandering if I could use the GSR crank in a LSVTEC setup to correct (or improve) the rod stroke ratio? Does it fit in the LS block or does it need to be machined to fit? Since the bore on the LS is the same as on the GSR and the stroke would be changed with the crank would the LS block stand up to higher revs (like a stock GSR block)? Thanks for any help
[Modified by EGCIV, 2:35 AM 2/6/2003]
Old Feb 6, 2003 | 07:10 AM
Cow's Avatar
Cow
Default Re: GSR crank in LSVtec ? (EGCIV)
That would defeat the whole purpose of LS/VTEC, which is the longer stroke of the LS crank.
Old Feb 6, 2003 | 09:00 AM
giooooo's Avatar
it will be a gsr again minus the oil squirters.
Old Feb 6, 2003 | 12:49 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: GSR crank in LSVtec ? (Giovannie)
03EM2guy
19
Mar 28, 2011 06:00 AM
Mostecstreethb
Feb 19, 2007 02:19 AM
turbodegsi
Nov 10, 2005 09:22 PM
black-hatch
Mar 13, 2003 08:54 PM
eddiecut
Aug 20, 2002 10:14 AM
