need help with a check engine light
Old Jan 19, 2003 | 12:00 AM
dre000's Avatar
Default need help with a check engine light
Someone was checking my car out tonight seemed like they wanted to steal it. Im not sure what it is, a friend told me to do this. There is a big grey plug to the left of the engine with multicolored wires coming out of it, I unplugged this so the car wouldnt start. Now I have a check engine light. Can anyone tell me what the plug is and why I have a cel now? Thanks in advance for any help.
Old Jan 19, 2003 | 01:06 AM
Adachi's Avatar
Default Re: need help with a check engine light (dre000)
That's just part of your wiring harness.. you plugged it up and it's still giving you a check engine light? Check the CEL code and see what the problem is.. you probably just need to reset the ecu.
Old Jan 19, 2003 | 01:19 AM
GirlyGS-R's Avatar
you definitly need to reset your ECU b/c u unplugged the main harness. just pull the ECu fuse or disconnect ur batt for a few seconds. when u start your car let it idle for a few min w/o stepping on the gas then you should be okay. if not bring it to your local acura dealer.
Old Jan 19, 2003 | 01:36 AM
dre000's Avatar
Default Re: need help with a check engine light (GirlyGS-R)
ok thanks
dojo19xx
Honda S2000
Oct 21, 2011 10:46 AM
88crx Osaka
Aug 20, 2011 10:42 PM
MattsGreenEG
Mar 19, 2008 09:21 PM
lowered94accord
Mar 16, 2007 08:27 AM
urgonnalearn2
Oct 20, 2003 11:54 PM
