Need quick clarification on valve's and firing order! HELP!!!
Old Feb 6, 2004 | 03:24 PM
TeamCracka's Avatar
Default Need quick clarification on valve's and firing order! HELP!!!
As some of you may know, I'm animating and constructing a motor in 3D.
Anyway, I'm trying to figure out how the cams and valves should operate. The firing order for our motors is 1-3-4-2 but here's my question.
Lets say cylinder 1 fires. The piston in cylinder 4 is at the identical place vertically but are the valves in cylinder 4 still allowing the compression of air and the expulsion of the compressed non-combusted air? Or, are the intake and exhaust valves in cylinder 4 just held open so that no compression occures?
Thanks to anyone who is familiar with this stuff , its starting to confuse me
Old Feb 6, 2004 | 05:03 PM
Sliced Beard's Avatar
Default Re: Need quick clarification on valve's and firing order! HELP!!! (TeamCracka)
as the #1 piston is at compression stroke the #4 is at exhaust stroke
each cylinder fires at every other release
so it has to travel up twice to get one explosion per cylinder
so when the #1 is on its "explosion" cycle the #4 is on the exhaust and
air pull cycle
this may have been more confusing but i am shure you are smart enough to figure out what i am saying
Old Feb 6, 2004 | 06:41 PM
yellow_jacket's Avatar
Default Re: Need quick clarification on valve's and firing order! HELP!!! (dirtyd463)
In other words, when the valves for cylinder number 1 are closed and it is compressing air, the exhaust valves on cylinder number 4 are open and it is pushing air out the exhaust as the piston comes up.
Old Feb 6, 2004 | 07:01 PM
Default Re: Need quick clarification on valve's and firing order! HELP!!! (yellow_jacket)
yeah thats it
d16gt2871r
Feb 25, 2015 01:15 PM
MeanusGeneus7
Honda CR-V & Element
14
Sep 18, 2012 08:35 PM
McDade
Jan 23, 2003 03:34 AM
B18EG6
Nov 18, 2002 08:54 AM
DragII
Dec 10, 2001 11:10 AM
