So I finally got home and did a compression and leakdown test...
Well, I returned home this weekend for the first time in three weeks after havign my car not running.
The compression test yielded the following numbers:
cyl 1: 220
cyl 2: 150
cyl 3: 220
cyl 4: 0
Then I did a leakdown test...I made sure the cylinders were at TDC when I performed the test...on the fourth cylinder, the air was rushing out of the exhaust. Looks like I will be replacing the exhaust valves on that cylinder. On the second cylinder, the air was hissing somewhere, kinda sounded like exhaust...and when I tapped the exhaust valves with an extension and a mallet, it was apparent that was the source.
My question is...how likely is it that I will need to replace anything in the block? The air didnt leak anywhere but the exhaust...
Given say...500-750 bucks what are my options for the head?
Thanks in advance, awaiting your responses...
Sebastian
cyl 1: 220
cyl 2: 150
cyl 3: 220
cyl 4: 0
Sebastian
Re: So I finally got home and did a compression and leakdown test... (B18EG6)
u may have to get some machjine work done to the head if the bent valves damaged it...
ghiscard had to send his to a machine shop after finding out he had bent vlaves
Re: So I finally got home and did a compression and leakdown test... (DevilSolSi)
Thanks alex...where did Ghis go to? I wasnt aware of many shops around home...
im not sure but aparently they fucked his up some how and had to buy him a new head and start over...I dont know exactly what the story is, and I am seriously starting to disbelieve that all this bad stuff could have happened to him on a simple motor swap...
drunk ****....
drunk ****....
zerovandez
10-03-2011 05:38 PM
ScottH23
04-10-2003 08:22 PM
