need new rings?
Old Jan 4, 2003 | 09:14 PM
1fastdc2's Avatar
Default need new rings?
I just did a compression test on my turbo b16 which is running a 9:1 compression ratio and got
#1 150
#2 147
#3 75
#4 155
Theirs smoke coming from the breather and I poured a little oil in #3 and got 95. I think its my rings but do you think it might be my headgasket or anything else you can think of. TIA.
Old Jan 4, 2003 | 09:44 PM
HookUpsImportTek's Avatar
Default Re: need new rings? (1fastdc2)
Well it might not be rings or anything to do with the block for that matter. Assuming you did the compression test right (ie : warmed the engine up and kept the throttle wide open) those numbers are low and do reflect leakage. Here are some possibilities:
1. Excessive revs have caused damage to your valves and thus causing leaks.
2. You have worn through your rings and they are excepting blow-by.
3. You have blown your headgasket.
Either way you are going to have to pull the head. The first thing I would do is a leak down on the head and check the headgasket. Make sure that the valves are leaking in the third or at least headgasket damage around the third else it is for sure your rings. Hope this helps. -HIT
[Modified by HookUpsImportTek, 10:53 PM 1/4/2003]
Old Jan 4, 2003 | 11:24 PM
flastreetscn's Avatar
new rings for cyl 3
Old Jan 5, 2003 | 07:47 AM
b19coupe's Avatar
If your compression goes up when you add oil to a cylinder, that is a good indication that the rings are the problem.
youryanyou
Apr 5, 2010 08:14 AM
Destructive-
Aug 21, 2009 08:24 PM
honda305
10
Feb 15, 2009 06:34 PM
silverboost
Nov 8, 2005 01:01 PM
98civicEX
Apr 8, 2003 10:55 AM
