need to know how to make 94 ls non abs
Old Jan 1, 2004 | 01:40 AM
bracket 4 life's Avatar
Default need to know how to make 94 ls non abs
can I just take it out and put in the rs system
Old Jan 6, 2004 | 08:43 AM
drumking15's Avatar
yes...if you go the rs route youll need to get everything from the rs..being the:
prop valve
front lines
brake booster
and master cylinder
an easier way is to stick w/ everything you already have, get a Rs prop valve and bend you won custom lines...much cheaper although rather hard to do w/ the motor in the car
Old Jan 6, 2004 | 08:52 AM
dip-set's Avatar
Default Re: (drumking15)
just pull the ebrake up just enough so the light on the dash shows that the ebrake is on..drive the car till u see the abs light come on on the dash,let the ebrake down,abs is deactivated till u turn the car off and restart it....
Old Jan 6, 2004 | 11:31 AM
Perfectionist's Avatar
Default Re: (teg-your-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">just pull the ebrake up just enough so the light on the dash shows that the ebrake is on..drive the car till u see the abs light come on on the dash,let the ebrake down,abs is deactivated till u turn the car off and restart it....</TD></TR></TABLE>
Or just pull the fuse.
Accord1234
May 4, 2008 07:28 AM
crxlex
Mar 4, 2007 09:19 PM
ingyplz
Jan 2, 2007 06:00 PM
Fabfive
Nov 17, 2002 01:50 PM
rob1208lv
Mar 19, 2002 07:08 AM
