need help from some engine builders
ok to start of it a ls b18b1 stock completley rebuilt new bearings new rings new gaskets new water pump oil pump and so on. my problem is i had it assembeled and they and come to find out the cylinders were not honed and when i started the motor it ran perfect then i go to start it again and smokes like a bitch there is blow by in the cylinders my question is if i take it all apart and have the cylinders bored within the service limit can i reuse the rings and if i do will they seat properly
i usually never reuse rings even after a simple start, usually if u let it idle for about 20 mins it will start to seat and then the perfect A/F will allow for a good break in after that, but just get some new ones
now im not sure because im only getting blow by in 2 cylinders im gonna pull the pistons and see if the rings are staggered correctly does any one know if u can get blow by if the rings are positioned at the pin or thrust surface
blackcrx16
17
Sep 18, 2007 10:45 PM
TURBO-JET LUDE
May 7, 2003 10:06 AM
