Need help on School Questions
Old Jun 3, 2003 | 03:48 PM
Newt's Avatar
Default Need help on School Questions
Hi I need help for the following questions of my high school auto course.
1. a "flooded" automobile engine results when too much gasoline is pumped into it
a) describe the appearance of the exhaust gas once you finally manage to start a "flooded engine.
b) what type of combustion does this represent
2. A carburetor is a device attached to an automobile engine in which gasoline and air are mixed prior to being burned. A lean fuel/air mixture contains less than a fuel/air mixture. which type of mixture would result in the cleanest automobile exhaust? why?
Old Jun 3, 2003 | 03:58 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Need help on School Questions (Newt)
a. the exh. will be really black cause your buring a ton of gas that was floded into the engine
b. an overly rich mixture/combustion
this is easy. if there is less gas being put into the engine, then there will be less coming out. A lean burn engine would make the cleanest exh.
next time, use the web, like google.
Blaze
Old Jun 3, 2003 | 04:10 PM
Newt's Avatar
Default Re: Need help on School Questions (Blaze45)
yea i shouldve used google. I already knew the answers
but i just wanted to make sure they are right, cause its an important assignment
thanks for the help
Carpartio
Classic Hondas
Jun 8, 2017 01:43 PM
timmav91
Jun 28, 2007 10:49 AM
ilsimsli
Welding / Fabrication
19
Jun 11, 2007 04:20 PM
ilsimsli
Apr 23, 2007 07:50 PM
delawaresfinest
Feb 3, 2005 10:58 AM
