Need help removing Valve Stem Seals!@
Old May 4, 2005 | 05:43 PM
Red D Dragon's Avatar
Default Need help removing Valve Stem Seals!@
Ok .. i have never removed valve stem seals before.. i figured while i had my head off it would be a good idea to replace em... but i cant seem to get them off and i dont have the little seal remover tool so i was wondering how do you guys get them off.. i tried prying and yanking them up but they dont seem to come off... any help would be great.... thanks...
~rob
Old May 4, 2005 | 08:04 PM
alright nm .. all it took was a little finess and some vice grips
Old May 4, 2005 | 08:53 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Need help removing Valve Stem Seals!@ (Red D Dragon)
get a pair of 90 degree needle nose pliers, and gently pull/wiggle them off
Old May 4, 2005 | 08:59 PM
ya thats pretty much what i ended up doing
Old May 4, 2005 | 10:22 PM
biotech0123's Avatar
Default Re: (Red D Dragon)
did it work? if not take it to a machine shop because in some cases they may have to be drilled out according to the Helms manual, or using something to heat the head up evenly and pull them out.
Old May 5, 2005 | 06:43 AM
IN VTEC's Avatar
For the real stubborn ones, I have to use the valve stem seal puller/slide hammer I bought from Goodson. Most of the time I can get them with just pliers or valve stem seal pliers.
Old May 5, 2005 | 10:16 AM
biotech0123
your thinking of valve guides not valve seals....
and i wish i had a valve stem puller slide hammer.... do they make valve stem seal pliers? but ya i just used pliers and vice grip and finessed em out... ...m mmmm new valve seals
jasoncrashtech
May 25, 2013 08:10 PM
Atomic1
Mar 27, 2010 08:57 PM
itr1244
Apr 10, 2006 07:39 AM
hu
Mar 29, 2006 10:17 AM
1.8EG-T
Dec 14, 2003 02:56 PM
