need help pulling this axle out
Old Aug 15, 2002 | 05:52 AM
BoM's Avatar
BoM
Default need help pulling this axle out
the axle nut is out, but i can't seem to pull out the axle from the brakes
everything is out of the car.
Old Aug 15, 2002 | 05:57 AM
keithv's Avatar
Default Re: need help pulling this axle out (BoM)
compress both CV joints and hit the end of the axle with a 3lb sledge. make sure to put the axle nut back on so you don't damage the threads.
Old Aug 15, 2002 | 06:51 AM
BoM's Avatar
BoM
Default Re: need help pulling this axle out (breaka_1_9)
no use, their stuck really bad.
how much do new ones go for?
i just need the passenger one for gsr
Old Aug 15, 2002 | 07:09 AM
keithv's Avatar
with a core exchange to autozone, they are about $70.
Old Aug 15, 2002 | 07:25 AM
BoM's Avatar
BoM
u think i can exchange one of my civic ones and get an integra one?
since the thing is stuck.
Old Aug 15, 2002 | 07:35 AM
keithv's Avatar
you probably can but they might charge you a little more. its worth a try...
Old Aug 15, 2002 | 08:31 AM
Brian_92GSR's Avatar
New User
You could cut the shaft in half and they would still take them.
Old Aug 16, 2002 | 12:38 AM
kinesistech's Avatar
Default Re: need help pulling this axle out (Brian_92GSR)
You're on drugs. Find better axles. The axles they give you is are a piece of ****. Every one you exchange it for every other week will also be a POS. I use an air hammer for those axles that think they're better than me. A hammer will do just fine.
Old Aug 16, 2002 | 01:38 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: need help pulling this axle out (kinesistech)
how 'bout a huge gear puller? if you in US, check for most autostores that rent tools, or buy a kit you should have one anyway.
stan
Old Aug 16, 2002 | 10:31 AM
John's Avatar
New User
Have you tried using an axle fork?
Old Aug 16, 2002 | 10:46 AM
93CivicSI's Avatar
Rent a Gear puller from Autozone or buy one from Sears
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
swarley
Jan 28, 2011 06:56 AM
bara6075
Oct 3, 2007 04:36 PM
sirt_eg
Jun 11, 2007 03:02 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
