How does the lower ball joint come off?
Old Aug 16, 2002 | 07:10 AM
senpai's Avatar
Default How does the lower ball joint come off?
This is the lower ball joint. I need the WHOLE thing to come out of the knuckle so I can replace it. The bottom threads are BAD!
Here is a picture:
It is number [3] in that picture.
THANKS!
Old Aug 16, 2002 | 07:12 AM
Spade's Avatar
Default Re: How does the lower ball joint come off? (maztur)
Re-thread it.
Old Aug 16, 2002 | 08:53 AM
PyroVTEC's Avatar
New User
You might want to buy a ball-joint remover tool from an auto parts store such as NAPA or Pep-Boys. It'll be easier to remove that way.
Old Aug 16, 2002 | 09:33 AM
92sleepR's Avatar
New User
you press it up, out of the knuckle. You have to remove the axles to do this but its really not that hard if you have a press. If you don't have the proper tools though don't F' with it. I had a small mom n' pop garage do it for like $35 a side.
Mike
Old Aug 16, 2002 | 09:36 AM
Katman's Avatar
Here is a picture:
THANKS!
You have to get it pressed out at your local automotive shop. They have tools to do it there. I dont think you can do it on your own, unless you have a press.
Old Aug 16, 2002 | 10:49 AM
93CivicSI's Avatar
Rent a ball joint press - remove the knuckle from the car - should take you about 20 minutes for the whole job.
ZOMBIEKILLER
Suspension & Brakes
11
Feb 24, 2008 05:51 PM
Dwight Schrute
Apr 20, 2007 03:42 PM
ice11honda
Aug 30, 2004 05:50 PM
xerox445
Feb 9, 2004 09:54 AM
senpai
Aug 17, 2002 02:06 AM
