NEED HELP PLEASE YOUNG ROOKIE
So I bought a civic 3 days ago so happy about the buy didn't even it's a registered yet long story short I begin to let the car run the first night I got it and then I pulled the ignition coil out cylinder one then the car shut off and it never cut back on
(( SUPER BINE HEAD MOVE I KNOW. But now it just cranks for ever and has a lil back fire sound. I put a new dizzy on wires and spark plugs the main relay clicks 2wice and the fuel pump cuts on no fried fuses nothing I can't find the problem can some one give me some insite please
I assume when you say, "I pulled the ignition coil out cylinder one" you mean the spark plug lead.
If so, it is my guess the coil is blown, get an HEI spark tester, [$10 or less at any auto parts store] and test for spark, I'm guessing you do not have any.
Just pulling a spark plug lead or not using an HEI spark tester can blow the coil, especially a weak coil.
hei spark tester | eBay 94
Wait what????
You said you have a 2000 Civic LX with a D16y7 engine, are you sure or has the engine been modified for multi coil setup instead of distributor ???? 94
Post a pix.
Is this your engine... JDM 96 00 Honda Civic D16A vtec Longblock Engine D16Y8 Motor OBD2 | eBay
If so, it is a distributed engine with one coil and one ICM. [igniter] both are in the distributor assembly, as mentioned you have replaced the spark plug leads
s2kkk
20
Apr 15, 2004 11:12 AM
