Need help!!! New motor!! :(
Old Dec 29, 2004 | 09:06 PM
GDM Z28's Avatar
Default Need help!!! New motor!! :(
ok i have a freshly built ls/vtec with je and eagles. the motor has 150 miles on it and it was open header for the first 90miles....now i have a 3" on and the exhaust tone isnt right. it kind of sounds like a wrx and it back fires alot.....by the sound my friend thought it was cam timing, bent valve, or rings werent sealing so i did a comp check and it was 160 dead on, on all 4 cyl's (motor is 9:1 and rings arnt sealed all the way). now my ? is what could be causing the noise and back fires? could it be dizzy timing, running too rich (255LPH fuel pump the gauge shows it running at like 50-60psi fuel pressure), or could it be the fact that i have 4 bolts holding my header on? someone please help....
Old Dec 29, 2004 | 10:25 PM
GDM Z28's Avatar
Default Re: Need help!!! New motor!! :( (civicflnum1)
someone please help?
Old Dec 29, 2004 | 10:44 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">(255LPH fuel pump the gauge shows it running at like 50-60psi fuel pressure), or could it be the fact that i have 4 bolts holding my header on?</TD></TR></TABLE>
is this with the vacuum hose on/off the fpr and is it adjustable? Fix your header and see what happens.
Old Dec 30, 2004 | 06:34 AM
GDM Z28's Avatar
Default Re: Need help!!! New motor!! :( (eda6)
thats with it on...i didnt take it off to check WOT....ill fix the exhaust leak today and turn down the FPR and look into it some more.
TURBODEEZ
Oct 11, 2005 02:38 PM
kentuckyprelude
Nov 13, 2004 11:49 AM
SLOAZZ95
Jul 15, 2004 07:12 AM
kefka
Jun 21, 2004 09:59 PM
boosted_zc
Apr 22, 2004 01:21 PM
