NEED HELP WITH MY INTEGRA
Old Jul 2, 2009 | 04:20 PM
yamaha99's Avatar
New User
Default NEED HELP WITH MY INTEGRA
I HAVE A 92 ACURA INTEGRA MY PROBLEM IS THE CAR TURNS OVER BUT WONT START IM NOT GETTING POWER TO ONE OF THE HARNESS TO THE DISTRIBUTOR WHAT COULD THAT BE ALSO I HAVE A NEW OEM DISTRIBUTOR, NEW FUSES NEW BATTERY NEW FUEL PUMP CAN ANY ONE HELP ME
Old Jul 2, 2009 | 05:31 PM
KWayRacing's Avatar
Default Re: NEED HELP WITH MY INTEGRA
Yes. Does your car have a no spark condition or a no fuel condition while cranking the engine? Simply do you have spark arc at the end of the spark plug wire whle holding it 1/4 inch from ground source(valve cover nut). OR DOes your vehicle have a no fuel condition? No fuel from fuel feed line when loosened at fuel filter. OR both? Watch the check engine light when you put the key in the ignition and turn the car on or to the second ignition switch position also known as KOEO Key on engine off. What does the light do? Does it light constantly or does it light for 2 seconds and go out or does it light for 2 seconds go out and then come right back on or does it not light at all? Do you know how to check the engine timing? ANyway, more info please?
scooby0007
Apr 27, 2019 02:53 PM
Benito89
12
Aug 12, 2011 05:14 AM
kike1994
Jan 22, 2010 10:24 PM
92awd4u
Sep 27, 2004 09:23 PM
FuzzyGreen
Nov 8, 2001 04:02 PM
