need help ... knock sensor .. i hondata s300
Old Apr 23, 2007 | 03:36 PM
monty Si-R's Avatar
Default need help ... knock sensor .. i hondata s300
ok here it goes i have a N/A motor LS/VTEC i have couple of mods in it .. but for some reason im still getting a engine light .. i check it out and it was a knock sensor .. now my question is why ????? bad motor or what ?
Old Apr 23, 2007 | 06:42 PM
Hondaruss's Avatar
Default Re: need help ... knock sensor .. i hondata s300 (monty Si-R)
did you install the Knock sensor. you can disable the knock sensor in the pref. and then Misc. and disable the knock sensor. if you didn't install the knock sensor disable it.
and buy throwing the code doesnt mean you have a bad motor
Old Apr 23, 2007 | 07:09 PM
monty Si-R's Avatar
ok im going to try to disable the knock sensor , but can that be bad for the motor ? cause i read about it and besically its a detonation and thats bad ryt ?
Old Apr 24, 2007 | 07:24 AM
NJcoupe's Avatar
PM'd
Old Apr 24, 2007 | 10:41 AM
Spunkster's Avatar
What ecu are you using?
Old Apr 24, 2007 | 10:26 PM
monty Si-R's Avatar
p72 with S300
Old Apr 25, 2007 | 10:02 AM
Spunkster's Avatar
Default Re: (monty Si-R)
Since this is a non-vtec block, where did you mount your knock sensor?
Old Apr 25, 2007 | 05:26 PM
monty Si-R's Avatar
well i dont know .. i guess the mechanic didnt put it on ... that could be my problem .. B18A ... would that be a problem for me in a long run ?? thanks for help spunkster and everybody out here ..
gabrielsousa
Nov 4, 2015 04:12 PM
Boost_em1_
May 29, 2014 04:21 AM
92ludeport
Jul 8, 2005 02:08 PM
delslow94
Dec 26, 2002 12:52 PM
