Need Help with Hondata
Old 01-03-2008, 01:24 PM
Hellraising Vtec's Avatar
Default Need Help with Hondata
Hi, i have a hondata s200 that i am putting on my civic. The this is that i dont know alot about tunning and i am going n/a but want to pray it with nitrousin some occations. When going nitrous the setup changes and i want to be capable of changing when i go nitrous and when i go n/a. I know of people that have used the 2 step from xenocron.com and it has worked fine. It has 2 chips and they can be set up differently. Just change a switch or something like that. The problem is ii've heard that that same thing can be done with the hondata without having to buy that 2 step. Is it true? I don't know alot about tuning and i want to be capable of changing without using a laptop. I will apreciatte any help. Thanks
Old 01-04-2008, 06:39 AM
Default Re: Need Help with Hondata (Hellraising Vtec)
anyone?
Old 01-05-2008, 02:02 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellraising Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Hi, i have a hondata s200 that i am putting on my civic. The this is that i dont know alot about tunning and i am going n/a but want to pray it with nitrousin some occations. When going nitrous the setup changes and i want to be capable of changing when i go nitrous and when i go n/a. I know of people that have used the 2 step from xenocron.com and it has worked fine. It has 2 chips and they can be set up differently. Just change a switch or something like that. The problem is ii've heard that that same thing can be done with the hondata without having to buy that 2 step. Is it true? I don't know alot about tuning and i want to be capable of changing without using a laptop. I will apreciatte any help. Thanks
If you are running hondata s200, contact your local hondata dealer for tuning & an explanation of how to use the features that come with the unit. I.E. launch control/nitrous control etc.
If you plan on trying to tune the car your self, you may want to look into a hondata s300 system as the romeditor v4 + tuning hardware is not cheap nor user friendly.
Old 01-05-2008, 02:09 AM
Seminole's Avatar
Default Re: Need Help with Hondata (mtber)
go to a shop that specializes in Hondata tuning :-)
Old 01-05-2008, 05:50 AM
thanks
CaymanNational
01-05-2008 07:33 AM
kornerk12
16
02-25-2007 06:22 PM
43MA
01-25-2005 10:09 PM
BLKCRX
01-21-2005 11:36 PM
XRC-88
05-08-2004 09:58 PM
Quick Reply: Need Help with Hondata
