Need Help....H22 questions
Old Aug 21, 2004 | 05:59 PM
darockjc's Avatar
Default Need Help....H22 questions
I just finished the rebuild of my h22. I got it started tonight finally. Once started we set the idle at 2500 b/c i put the stage 2 crowers in and they said to not let idle under 2000 for 30 minutes or so. After about 15 minutes the exhaust manifold was glowing from the heat. I have never before seen this happen on a honda and was wondering what could be happening or causing this and if this has happened to antone else. The car is full of coolant.
Old Aug 21, 2004 | 06:03 PM
Dragline's Avatar
Default Re: Need Help....H22 questions (darockjc)
check you converter it may be clogged
Old Aug 21, 2004 | 11:01 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Need Help....H22 questions (dragline)
yeah that or the engine's running super lean. Make sure you're getting enuogh fuel.
Old Aug 22, 2004 | 07:31 AM
darockjc's Avatar
Default Re: Need Help....H22 questions (PreIudeSI)
yeah i thought that too so i upped the fuel pressure from 40 to 44 but then it still seemed to do it. Just wondering what type of fuel pressure most people run? I have AEM fuel rail and bigger injectors w/AEM CAI and then the motor has supertech valves, valve springs and retainers and then the crower stage 2 cams? Also what rpm should this be able to handle?
nihad
Jul 11, 2009 08:17 AM
dunkd
Feb 10, 2008 06:22 AM
superturboprelude
May 27, 2007 08:34 AM
sleeperHatch
Apr 22, 2004 05:12 PM
thehondaguru
Apr 20, 2004 08:51 AM
