aem fuel regulator
Ok i have a aem fuel regulator its not universal its the one that bolts to the rail older honda style. What fitting should i have inside it so it is compatable with a walbro 255..
And is it normal to drop in vacuum from 22 to 13 from stock d16 injectors 235cc to 780cc
they are peak and hold style.. I was thinking its doing this because its untuned yet this was at idle.... about 40-42psi on the regulator at idle..
get a basemap for your injector size and setup before you mess something up.
just use the middle sized orfice and bring the others with you to the tune just in case.
superturboprelude
May 27, 2007 08:34 AM
thehondaguru
Apr 20, 2004 08:51 AM
