Need help with engine problem
Old May 3, 2005 | 10:39 PM
Soku1kcivic's Avatar
Default Need help with engine problem
Hi, I have a 94 honda civic ex coupe automatic its all stock with d16z6, I recently replace the dizzy and it ran perfect. Its been a month now the motor started act funny when its warmed up, if u open the throttle in P really quick it hesistates then picks up rev. and if your in D and hold the brake down the motor will have a quick irregular shake then idle normal again. I have swap out a new dizzy with new cap and rotor, check the spark plugs. check the belt timing, swap in another map sensor. No check lights. Any idea's ? Iam aiming at the fuel system next
And also i cleaned the Iac and TB, same thing all mounts are fine no rips it never did this before, kinda strange Thanks.
Old May 4, 2005 | 07:15 AM
Kendall's Avatar
Check your grounds.
Old May 5, 2005 | 08:47 PM
Default Re: (Kendall)
bump
MMMGIRL
Apr 22, 2012 10:21 AM
Ghost78
Apr 22, 2009 02:50 AM
jordan_civic
May 30, 2008 10:35 PM
ipihuc
Oct 4, 2007 07:07 PM
Soku1kcivic
May 3, 2005 08:48 PM
