Need help with engine burningoil and antifreeze
Trying to help a buddy out. Had block bored .20 over, decked, head surfaced. He put eagle rods and ross pistons in buy himself. Now the problem, When he starts the car, it uses alot of antifreze and it burns some oil too( meaning through the exhaust pipe). He has already gone through 5 headgaskets and still has not solve this problem. There is oil in the radiator so I think it is the headgasket but he has already been through a few. You guys think this could have been some kind of machine work error?
Another thing also is with the ross piston, is their a piston ring that you do not need to use?
Sounds like a warped head or incorrect torque specs on the bolts.
With the Ross pistons, there isn't an "extra" ring that you can or cant use. Even if it was the rings, the loss of coolant is weird. These are OEM head-gaskets, yes?
civic-8442-
May 13, 2010 12:24 PM
Shwanky420
Oct 29, 2005 09:01 PM
