Need help with e85 fuel system
Old Apr 29, 2016 | 09:01 AM
Michael Acevedo's Avatar
Default Need help with e85 fuel system
Hello I'm kind of stuck on what to do next I really don't have any experience with ethanol and I have a fresh build that I want to run E85 on my setup is 81.5 X 89 mm 12.5 usdm Integra Type R Pistons lsvtec running OEM Type R cams any info I would greatly appreciate it thank you
Old Apr 29, 2016 | 09:34 AM
jdblock's Avatar
Default Re: Need help with e85 fuel system
Besides a bigger fuel pump and injectors, you'll need to get tuned.
Best thing to do is ask your tuner what he prefers to tune. Some like certain brand/size injectors.
Old Apr 29, 2016 | 09:49 AM
As of right now I have a stock fuel system but I've started to gather parts so far this is what I have
●450lph walbro fuel pump (e85 compatible )
●napa 4003 fuel filter
●aem fuel rail
●nitrous express fuel pressure regulator
●injector dynamics 1000cc injectors
Where I'm stuck at is determining what size/type feed and return lines to run
I'm just trying to go to mexico soon
Old Apr 29, 2016 | 09:52 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
I ran a walbro 450, ID1000s with stock lines besides from the factory fuel filter to the rail, and rail to FPR. This supported 560WHP on e85.
So run any sized lines you want, typically people run -8 feed and -6 return. You can use as much factory lines if you want and it will be fine for your setup
jdblock's Avatar
Why are you trying to run such a big pump? Are you turbo'd?
Same with the fuel lines. Why do you think the stock ones are restrictive? The bigger your pump and fuel lines, the more fuel is going to be returned to the tank for no reason.
Old Apr 29, 2016 | 10:25 AM
Reason I got a 450 pump was because I have plans of slapping a turbo on but that's a while from now just planning ahead
Old Apr 29, 2016 | 10:33 AM
For example is this filter too big? Its bigger than my rail lol
Old Apr 29, 2016 | 10:39 AM
jdblock's Avatar
Is this a daily?
Old Apr 29, 2016 | 10:41 AM
Yes will be daily driven
Old Apr 29, 2016 | 11:07 AM
cool fuel filter, lol what micron is it? and what fuels is it good for?
Old Apr 29, 2016 | 11:09 AM
7 micron e85 compatible
Old Apr 29, 2016 | 11:18 AM
jdblock's Avatar
Find a tuner and talk to them about your goals.
Two smaller fuel pumps might be better for a daily so you aren't returning huge amounts of fuel back into the tank. One for cruising around, and the second kicks in when it's needed.
Fuel pumps heat fuel and if enough is returned to the tank you just end up with hot fuel. Hot fuel isn't as dense as cool fuel, and if it gets hot enough, you can run lean at the wrong time and pop your engine. This isn't so much of an issue if you have a fuel temp sensor and the car is tuned for it, but that requires some fancy parts and ECU tuning.
Old Apr 29, 2016 | 03:12 PM
Thanks I will look into this appreciate it guys ��
Old Jun 6, 2016 | 08:54 AM
Soo has anyone ran a non bypass fuel pressure regulator? I have this regulator but I'm not sureally if it will work on a honda setup
Old Jun 6, 2016 | 08:58 AM
<br >
Old Jun 6, 2016 | 09:09 AM
<br >
Steeve_Civic
Aug 7, 2012 05:53 PM
92EGminihatch
May 22, 2009 02:08 PM
big juan
Oct 29, 2005 06:59 AM
Joel_MN
Aug 17, 2003 11:59 AM
Hispeed
Jul 30, 2001 10:12 AM
